Hi, I’ve got an arduino nano esp32 that’s stuck in DFU mode. It doesn’t show up as a COM port, only as a USB DFU device in device manager. I’ve tried:
Pressing reset once and double-tapping reset
Arduino web flasher (never detects the board)
Using arduino-cli (but it can't see any ports)
esptool.py (fails to connect bc no serial port)
dfu-util (can't find correct firmware offsets for nano esp32)
different USB cables and ports
I’ve installed the arduino agent, tried chrome/edge, still no detection. I just want to restore the board to factory firmware so it shows up again as a normal serial device.
Any ideas? is there a way to fully recover this thing from DFU mode?
Hello @cr_txt, sorry for the delay. Not sure what is happening on your board, but have a look at this procedure, it will definitely recover it you only need the Arduino IDE and the Arduino ESP32 boards package.
Let us know if you were able to reflash your Nano ESP32!
The Arduino functions correctly on another PC, but not on mine. It appears that my system does not recognize any serial/COM port associated with the Arduino—only the DFU port is detected. I have attempted to reset the firmware and burn the bootloader (on the other computer, as mine fails to detect the COM port), but neither method was successful.
