Yay!
a7
Yay!
a7
You may have damaged the Dout of the final LED when connecting to it as if it was an input, but if that is the last LED in the chain that doesn't matter. I do want to make very clear that the 5v USB you are now using to power both the Nano and the LED-strip is limited to 500mA (for all devices connected to that Hub) which is not very much, and not the best to power LED-strip
Yes, keep in mind that you did that. For example, I have ICs that work, but have a note on them like ābeen too hotā to remind myself that I have a potential problem in the future, and to not use that in any way critical.
But if you always had the resistor (hmm!) in the circuit, it may have kept that from happening.
a7
I keep IC's that i use in development separate from the ones i use in usable projects. But if in doubt i actually just chuck them in the bin.
The resistor might have saved the strip ![]()
One possible reason can be that it prevents the strip from being powered from the Din pin when the controller is on but the strip is off.
I stopped resisting <- see what I did there? some time ago, dunno if this thread was the last time I even bothered to wonder anymore
HTH
a7
Iām planning to power 8 pixels from 3.3v and use 3.3v board, do you think resistor might be risky here?
It is never risky.
Well WS2812b's aren't quite as bright at 3.3v
I found them painfully bright at 5v and full throttle so no problem
If they work at all. Never tried, but the data sheet or a data sheet, such as it is, sez
Power supply voltage VDD+3.5~+5.3 Volts
so youāll need a level shift on the data line, traditional or hack, and youāll want to just use 5 volts power.
But try it and see and tell us how it works.
a7
You will have some red-shift, which is also seen with poor supply/wiring and long strings.
The blue and green LEDs have a higher Vf (working voltage) than the red LEDs,
which makes them to go dimmer with voltage deprivation before the red LEDs do.
Leo..
No experience with 3.3V on WS2812Bs. It's my understanding that it might work although outside its specs; general advise is to use 74HCT14s as level shifters and use 5V for the HCT and the strip.
Yes they do.
Yes significantly less brightness on the Blue channel.
If possible that is the proper way to do it.
