Arduino Nano Every Sleep Mode
Although this topic has been discussed a couple of times here, they were all closed without a working solution, which is quite frustrating. Anyways...
I'm trying to wake the Atmega4809 (Nano Every) from a sleep mode, which much like Sleeping Beauty, is easy to put to sleep, but nearly impossible to wake-up.
I've got working code for sleep mode mode with timer wake-up, but I need the seemingly simple option of waking from a digital input interrupt. Although I've tried several methods, from simple to slightly more bitwise conscious, nothing seems to work.
Here is the code for what I believe to be the closest (though still no cigar):
This program will put the ATMEGA in a sleep mode
and should !! wake it up via a hardware Interrupt, INT0
 ---> Pin2 Wake-Up NOT working...
#include <avr/sleep.h>
#include <avr/interrupt.h>
#define interruptPin 2
unsigned long wakeUpMillis = 0;
bool IntAttached = true; // Interrupt is attached
int buttonState = 0;
 Serial.begin(9600);//Start Serial Comunication
 pinMode(LED_BUILTIN,OUTPUT);
 pinMode(interruptPin,INPUT_PULLUP);
 //attachInterrupt(digitalPinToInterrupt(interruptPin), goToSleep, LOW);
 Serial.print("Start Up | ");
 digitalWrite(LED_BUILTIN,HIGH);
 digitalWrite(LED_BUILTIN,LOW);
 buttonState = digitalRead(interruptPin);
 //if (!IntAttached && millis() - wakeUpMillis > 2000)
 if (buttonState == HIGH)
   Serial.print("SLEEP");
   //goToSleep();
   noInterrupts();
   interrupts();
   IntAttached = true;
void goToSleep()
 Serial.println("Going to sleep...");
 sleep_enable();                       //Enabling sleep mode
 noInterrupts();
 attachInterrupt(digitalPinToInterrupt(interruptPin), wakeUp, RISING);
 set_sleep_mode(SLEEP_MODE_PWR_DOWN);
 delay(2000);
 interrupts();
 sleep_cpu();//activating sleep mode
 // Now the µController is asleep...
 // will resume from here
 Serial.println("just woke up!");
void wakeUp()
 noInterrupts();
 detachInterrupt(digitalPinToInterrupt(2));
 interrupts();
 IntAttached = false; // Interrupt is detached.
 Serial.println("Interrupt Fired");
 sleep_disable();
 wakeUpMillis = millis();
Any suggestions or fingers pointing in the right direction would e greatly appreciated.
Thanks!
You want to the interrupt to wake up the processor.
But: on interrupt you call the function goToSleep.
Thank you @stitech, that definitely helped me look in a more specific direction.
I found this post that I managed to integrate into my main code quite easily, with a working interrupt on D2: LINK
All running quite nicely now.
