Arduino Nano I2C OLED display 0.96 inches 128x64 pixels
I have a strange issue while trying to run the hello world code on an arduino nano connected to an OLED display.
This is the code I used:
#include <Adafruit_SSD1306.h>
Adafruit_SSD1306 display = Adafruit_SSD1306(128, 64, &Wire);
  // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // Address 0x3C for 128x32
  display.display();
  delay(2000);
  display.clearDisplay();         //this line to clear previous logo
  display.setTextColor(WHITE);    //without this no display
  display.print("Hello World!");  //your TEXT here
  display.display();              //to shows or update your TEXT
void loop() {}
But I get this on the display:
Any idea what I could be missing?
Thanks !
You are probably missing nothing.
The simulation of your sketch works:
Your OLED display might do something weird.
I assume that if you buy a OLED from Adafruit, that it will work.
Do you see the logo appearing on your OLED display ?
The address jumper on the back of the display does not seem to match the address you are calling in your code. 0x3C //for a 128x32 display vs. (what appears to be 0x7? (maybe 70 or 78 or 7B) on the back of the board.
However, I would think you would get nothing displayed at all!
If that is not an Adafruit sourced display, it might not be a SSD1306 control chip.
Looks like a problem with the font, the exclamation mark is correct, and the characters are consistent where they appear more than once (the double l in Hello and the o on each word).
I recall seeing a similar when I first used that display. I never knew what the real problem was. It might have been me. You might find this link useful.
