I'm trying to use 2 Arduino Nano RP2040 Connect boards to transmit and receive data wirelessly with NRF24L01+ chips.
Arduino: link
NRF24L01+ chips: link
I'm using this CircuitPython library, I drag the "circuitpython_nrf24l01" folder onto the root of my CIRCUITPY drive. My code.py file is roughly the library's "examples/nrf24l01_simple_test.py" (hardcoding if I'm using it in transmit or receive mode)...
Simple example of using the RF24 class.
import time
import struct
import board
import digitalio
# if running this on a ATSAMD21 M0 based board
# from circuitpython_nrf24l01.rf24_lite import RF24
from circuitpython_nrf24l01.rf24 import RF24
# change these (digital output) pins accordingly
ce = digitalio.DigitalInOut(board.D4)
csn = digitalio.DigitalInOut(board.D5)
# using board.SPI() automatically selects the MCU's
# available SPI pins, board.SCK, board.MOSI, board.MISO
spi = board.SPI() # init spi bus object
# we'll be using the dynamic payload size feature (enabled by default)
# initialize the nRF24L01 on the spi bus object
nrf = RF24(spi, csn, ce)
# set the Power Amplifier level to -12 dBm since this test example is
# usually run with nRF24L01 transceivers in close proximity
nrf.pa_level = -12
# addresses needs to be in a buffer protocol object (bytearray)
address = [b"1Node", b"2Node"]
# to use different addresses on a pair of radios, we need a variable to
# uniquely identify which address this radio will use to transmit
# 0 uses address[0] to transmit, 1 uses address[1] to transmit
# radio_number = bool(
# int(input("Which radio is this? Enter '0' or '1'. Defaults to '0' ") or 0)
radio_number = 0
# set TX address of RX node into the TX pipe
nrf.open_tx_pipe(address[radio_number]) # always uses pipe 0
# set RX address of TX node into an RX pipe
nrf.open_rx_pipe(1, address[not radio_number]) # using pipe 1
# using the python keyword global is bad practice. Instead we'll use a 1 item
# list to store our float number for the payloads sent
payload = [0.0]
# uncomment the following 3 lines for compatibility with TMRh20 library
# nrf.allow_ask_no_ack = False
# nrf.dynamic_payloads = False
# nrf.payload_length = 4
def transmit_data(count=1000):
"""Transmits an incrementing integer every second"""
nrf.listen = False # ensures the nRF24L01 is in TX mode
while count:
# use struct.pack to packetize your data
# into a usable payload
buffer = struct.pack("<f", payload[0])
# "<f" means a single little endian (4 byte) float value.
start_timer = time.monotonic_ns() # start timer
result = nrf.send(buffer)
end_timer = time.monotonic_ns() # end timer
if not result:
print("send() failed or timed out")
else:
print(
"Transmission successful! Time to Transmit: "
"{} us. Sent: {}".format(
(end_timer - start_timer) / 1000, payload[0]
payload[0] += 0.01
time.sleep(1)
count -= 1
def receive_data(timeout=1000):
"""Polls the radio and prints the received value. This method expires
after 6 seconds of no received transmission"""
nrf.listen = True # put radio into RX mode and power up
start = time.monotonic()
while (time.monotonic() - start) < timeout:
if nrf.available():
# grab information about the received payload
payload_size, pipe_number = (nrf.any(), nrf.pipe)
# fetch 1 payload from RX FIFO
buffer = nrf.read() # also clears nrf.irq_dr status flag
# expecting a little endian float, thus the format string "<f"
# buffer[:4] truncates padded 0s if dynamic payloads are disabled
payload[0] = struct.unpack("<f", buffer[:4])[0]
# print details about the received packet
print(
"Received {} bytes on pipe {}: {}".format(
payload_size, pipe_number, payload[0]
# recommended behavior is to keep in TX mode while idle
nrf.listen = False # put the nRF24L01 is in TX mode
if __name__ == "__main__":
try:
transmit_data()
# receive_data()
except KeyboardInterrupt:
print(" Keyboard Interrupt detected. Powering down radio...")
nrf.power = False
else:
print(" Run slave() on receiver\n Run master() on transmitter")
The transmitter keeps giving the error "send() failed or timed out"
My debugging....
I've tested my RF24 chips on regular Arduino Uno R3 boards, and they talk just fine using the official RF24 library
I've attached the Fritzing diagram for the regular Arduino Uno boards
here's the Arduino Uno R3 transmitter's code:
* Arduino Wireless Communication Tutorial
* Example 1 - Transmitter Code
* by Dejan Nedelkovski, www.HowToMechatronics.com
* Library: TMRh20/RF24, https://github.com/tmrh20/RF24/
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(9, 10); // CE, CSN
const byte address[6] = "00001";
radio.begin();
radio.openWritingPipe(address);
radio.setPALevel(RF24_PA_MIN);
radio.stopListening();
const char text[] = "Hello World";
radio.write(&text, sizeof(text));
- here's the Arduino Uno R3 receiver's code:
* Example 1 - Receiver Code
#include <SPI.h>
#include <RF24.h>
radio.begin();
radio.openReadingPipe(0, address);
radio.startListening();
if (radio.available()) {
char text[32] = "";
radio.read(&text, sizeof(text));
Serial.println(text);
I'd really appreciate any help in getting this to work on my new Arduino Nano RP2040 Connect boards!! I really want to make them into remote controllers for my robotics project!
Thank you,
Ryan
Fritzing for Arduino Uno:
Fritzing for Arduino Nano RP2040 Connect:
