Arduino nano schematic
Google can see through the 'mist':
CH340 Driver
My electronic components experience is about 15-20% but as a projects I have a very deep experience. I didn't connect them over a breadboard because they are SMD components and to save time too I just draw the schematic and ordered the board.
I made previously a board that I just connect the arduino over it but for this project I'm trying to make the arduino and the rs232 module both built in the same PCB board.
raschemmel:
A Nano uses an FT232L USB chip and requires a USB driver.
Does the CH340G require a driver and did you install it ?
Of course, if you use Mint (Linux), that becomes irrelevant. :roll_eyes:
OPs schematic and PCB.
Tom... :slight_smile:
Neither of the crystals in your schematic have load capacitors.
oops...
Should add 22pF caps from each pin to GND,
on both crystals.
I did three modifications to the circuit and finally succeed to program the chip using (upload using programmer option) BUT still when I burn the boot loader and connect the USB, the PC don't recognize the arduino to program it without using another arduino!!!
what I changed are(I marked what I changed in the schematic with a RED circle "attached"):
1- I added 1k resistor between the reset pin and 5V
2- Replaced the crystal resonator of the ch340g chip with another one (which I removed from another arduino nano which must be 12MHz as you mentioned)
3- Grounded the max3232 which it was not.
Please could you draw your suggestions over the schematic to clearly understand you.
thanks
Are those 16Mhz resonators or crystals?
I used this one for the ATmega CSTCE16M0V53-R0 Murata Electronics | C32180 - LCSC Electronics
But for the ch340g chip, I used one from another arduino nano which was for the same chip but I don't know any information about it.
Load caps on the X2 the 340 crystal and X1 on the 328.
Note under lined items.
I would suggest you remove U4 if you have it fitted.
Tom.... :slight_smile:
If you will notice, his PCB layout already includes the footprint for the resonators quoted, which integrate the load capacitors. :roll_eyes:
