HELP please: One Arduino Nano stuck at uploading after successful compile while other Nano board got uploaded no issue.
Arduino: 1.8.10 (Windows 10), Board: "Arduino Nano, ATmega328P"
Sketch uses 3154 bytes (10%) of program storage space. Maximum is 30720 bytes.
Global variables use 222 bytes (10%) of dynamic memory, leaving 1826 bytes for local variables. Maximum is 2048 bytes.
C:\Users\Vinh Dam\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\Vinh Dam\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\VINHDA~1\AppData\Local\Temp\arduino_build_223621/stepper_oneStepAtATime.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Vinh Dam\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x31
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Hi @mrvinh. I'm going to ask you to post the full output from the upload when in verbose mode.
NOTE: These instructions will not solve the problem. They are only intended to gather more information which might provide a clue that eventually leads to a solution.
Please do this:
Select File > Preferences from the Arduino IDE menus.
Uncheck the box next to Show verbose output during: ☑ compilation.
Check the box next to Show verbose output during: ☐ upload.
Click the OK button.
Attempt an upload to the board that exhibits the "stuck at uploading" behavior, just as you did before.
Wait for the upload process to finish.
Click on the black console panel at the bottom of the Arduino IDE window.
Press Ctrl+A to select all the text.
Press Ctrl+C.
This will copy the selected text to the clipboard.
Open a forum reply here by clicking the Reply button.
Click the <CODE/> icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
Press Ctrl+V.
This will paste the error output from the upload into the code block.
Move the cursor outside of the code tags before you add any additional text to your reply.
Click the Reply button to post the output.
Please let me know if you have any questions or problems while following those instructions.
was this board programmed before or it is first time?
does it appear in COM port list on connect to computer?
some board have old bootloader, did you already tried this option?
Hi Kolaha. This board was programmed many times before same set up as you described. I replaced with another Nano board and it got uploaded, this is the proof that the setup of IDE is good.
Stepper Motor Control - one step at a time
This program drives a unipolar or bipolar stepper motor.
The motor is attached to digital pins 8 - 11 of the Arduino.
The motor will step one step at a time, very slowly. You can use this to
test that you've got the four wires of your stepper wired to the correct
pins. If wired correctly, all steps should be in the same direction.
Use this also to count the number of steps per revolution of your motor,
if you don't know it. Then plug that number into the oneRevolution
example to see if you got it right.
Created 30 Nov. 2009
by Tom Igoe
#include <Stepper.h>
const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8, 9, 10, 11);
int stepCount = 0; // number of steps the motor has taken
// initialize the serial port:
// step one step:
myStepper.step(1);
Serial.print("steps:");
Serial.println(stepCount);
stepCount++;
Arduino: 1.8.10 (Windows 10), Board: "Arduino Uno"
Sketch uses 3154 bytes (9%) of program storage space. Maximum is 32256 bytes.
C:\Users\Vinh Dam\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\Vinh Dam\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\VINHDA~1\AppData\Local\Temp\arduino_build_20917/stepper_oneStepAtATime.ino.hex:i
Using Port : COM3
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xc8
I think is it possible that the previous running program's blocks the upload transfer? I wish there is a way to stop that program from running to try a new upload.
I was trying to burn bootloader to reset it but there is issue with the ID number I don't know how to deal with. I think I bricked those Nanos. What do you think?
Either the wiring was wrong or you have blown the 328P.
When posting code or error messages, please see point 11 in post #2 to apply so-called code tags. It makes it easier to read, easier to copy and the forum software will display it correctly.
Sorry I don't see any code. How do I attach code now?
I am sure the wring was right. The 328p was still running on the previous program so it is not blown.
