Hey Guys Im unable to upload to all my Arduino Nanos. Ive used the in a prevoius project and they worked fine. When Im uploading most of the time nothing happens but sometimes the Rx Led flickers randomly very dimly. Ive tried using multiple cables and arduinos and the all sem to have the same issue so Im guessing its something with my settings. Ive selsected arduino nano as a board and the correct COM Port. Ive tried both AVR ISPmkII as well as Arduino as ISP as Bootloaders.
Any tips?
The error message that shows if any shows at all is the avrdude one
AaronSilas:
If it shows one, please do what @pert asked.
FYI, AVR ISPmkII and Arduino as ISP ain't boot loaders, they are programmers. And they have no effect when you upload using USB.
Further, which IDE version are you using on which OS? Have you tried the different processor options?
Ill try that.
Im using the 1.8.8 but also tried the newest one on Windows 8.1
Here is the error code you asked for:
Arduino: 1.8.8 (Windows 8.1), Board: "Arduino Nano, ATmega328P"
Sketch uses 444 bytes (1%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
E:\Programme\Arduino\hardware\tools\avr/bin/avrdude -CE:\Programme\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\Aaron\AppData\Local\Temp\arduino_build_434785/sketch_feb05a.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "E:\Programme\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x7d
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
