Arduino IDE stopped uploading to arduino nano.
When working on a project, I went to upload updated code to my clone arduino nano, and it was stuck on uploading and said programmer not responding. I then tried another nano, same thing. I was able to still upload to my uno, so it must be a problem with the nano. I have used these nanos countless times, and now all of a sudden I can’t upload code. I tried updating the drivers, reinstalling IDE, and nothing worked. The loop back test didn’t work on either nano. I am sure I selected the right port, board, and processor. I have looked all over the forums and still haven’t found a solution.
Please do this:
  • (In the Arduino IDE) File > Preferences
  • Uncheck the checkbox next to "Show verbose output during: compilation"
  • Check the checkbox next to "Show verbose output during: upload
  • Click "OK"
  • Sketch > Upload
  • After the upload fails, you'll see a button on the right side of the orange bar "Copy error messages" (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
  • Press "Ctrl + V". This will paste the upload output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
Arduino: 1.8.13 (Windows 10), Board: "Arduino Nano, ATmega328P"
Sketch uses 1338 bytes (4%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\sebas\AppData\Local\Temp\arduino_build_119690/PWMTest.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc5
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc5
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xc5
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xc5
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc5
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xc5
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc5
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xc5
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xc5
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xc5
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Select Tools > Processor > ATmega328P (Old Bootloader) and then try uploading again.
Still doesn't work, here is the error code.
Arduino: 1.8.13 (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b57600 -D -Uflash:w:C:\Users\sebas\AppData\Local\Temp\arduino_build_667409/PWMTest.ino.hex:i
         Using Port                    : COM3
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x96
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x96
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x96
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x96
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x96
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x96
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x96
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x96
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x96
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x96
