DrAzzy:
God, what a dreadful library to have to dig through.
I took a quick look through library source, I couldn't figure out where they make their choice about what pins to use either. I think only one pin needs to be changed, and that is the slave select pin, which is on D8 instead of D10.
Found a better library but haven't tested yet, found the pin here as MAX_SS on 10, will try this later.
~~https://github.com/ribbotson/USB-Host/tree/master/ps3/PS3USB~~
EDIT: This is for USB cable only, no BT
I looked around in the first repo linked and tried finding the slave setup pin but the only relevant code I find is in the file avrpins.h
#define MAKE_PIN(className, pin) \
class className { \
public: \
static void Set() { \
digitalWrite(pin, HIGH);\
static void Clear() { \
digitalWrite(pin, LOW); \
static void SetDirRead() { \
pinMode(pin, INPUT); \
static void SetDirWrite() { \
pinMode(pin, OUTPUT); \
static uint8_t IsSet() { \
return digitalRead(pin); \
// 0 .. 13 - Digital pins
MAKE_PIN(P0, 0); // RX
MAKE_PIN(P1, 1); // TX
MAKE_PIN(P2, 2); //
MAKE_PIN(P3, 3); //
MAKE_PIN(P4, 4); //
MAKE_PIN(P5, 5); //
MAKE_PIN(P6, 6); //
MAKE_PIN(P7, 7); //
MAKE_PIN(P8, 8); //
MAKE_PIN(P9, 9); //
MAKE_PIN(P10, 10); //
MAKE_PIN(P11, 11); //
MAKE_PIN(P12, 12); //
MAKE_PIN(P13, 13); //
#undef MAKE_PIN
and
#define MAKE_PIN(className, baseReg, pinNum, configReg) \
class className { \
public: \
*GPIO_BITBAND_PTR(baseReg, pinNum) = 1; \
*GPIO_BITBAND_PTR(baseReg, pinNum) = 0; \
configReg = PORT_PCR_SRE | PORT_PCR_DSE | PORT_PCR_MUX(1); \
*(GPIO_BITBAND_PTR(baseReg, pinNum) + 640) = 0; \
*(GPIO_BITBAND_PTR(baseReg, pinNum) + 640) = 1; \
return *(GPIO_BITBAND_PTR(baseReg, pinNum) + 512); \
MAKE_PIN(P0, CORE_PIN0_PORTREG, CORE_PIN0_BIT, CORE_PIN0_CONFIG);
MAKE_PIN(P1, CORE_PIN1_PORTREG, CORE_PIN1_BIT, CORE_PIN1_CONFIG);
MAKE_PIN(P2, CORE_PIN2_PORTREG, CORE_PIN2_BIT, CORE_PIN2_CONFIG);
MAKE_PIN(P3, CORE_PIN3_PORTREG, CORE_PIN3_BIT, CORE_PIN3_CONFIG);
MAKE_PIN(P4, CORE_PIN4_PORTREG, CORE_PIN4_BIT, CORE_PIN4_CONFIG);
MAKE_PIN(P5, CORE_PIN5_PORTREG, CORE_PIN5_BIT, CORE_PIN5_CONFIG);
MAKE_PIN(P6, CORE_PIN6_PORTREG, CORE_PIN6_BIT, CORE_PIN6_CONFIG);
MAKE_PIN(P7, CORE_PIN7_PORTREG, CORE_PIN7_BIT, CORE_PIN7_CONFIG);
MAKE_PIN(P8, CORE_PIN8_PORTREG, CORE_PIN8_BIT, CORE_PIN8_CONFIG);
MAKE_PIN(P9, CORE_PIN9_PORTREG, CORE_PIN9_BIT, CORE_PIN9_CONFIG);
MAKE_PIN(P10, CORE_PIN10_PORTREG, CORE_PIN10_BIT, CORE_PIN10_CONFIG);
MAKE_PIN(P11, CORE_PIN11_PORTREG, CORE_PIN11_BIT, CORE_PIN11_CONFIG);
MAKE_PIN(P12, CORE_PIN12_PORTREG, CORE_PIN12_BIT, CORE_PIN12_CONFIG);
MAKE_PIN(P13, CORE_PIN13_PORTREG, CORE_PIN13_BIT, CORE_PIN13_CONFIG);
MAKE_PIN(P14, CORE_PIN14_PORTREG, CORE_PIN14_BIT, CORE_PIN14_CONFIG);
MAKE_PIN(P15, CORE_PIN15_PORTREG, CORE_PIN15_BIT, CORE_PIN15_CONFIG);
MAKE_PIN(P16, CORE_PIN16_PORTREG, CORE_PIN16_BIT, CORE_PIN16_CONFIG);
MAKE_PIN(P17, CORE_PIN17_PORTREG, CORE_PIN17_BIT, CORE_PIN17_CONFIG);
MAKE_PIN(P18, CORE_PIN18_PORTREG, CORE_PIN18_BIT, CORE_PIN18_CONFIG);
MAKE_PIN(P19, CORE_PIN19_PORTREG, CORE_PIN19_BIT, CORE_PIN19_CONFIG);
MAKE_PIN(P20, CORE_PIN20_PORTREG, CORE_PIN20_BIT, CORE_PIN20_CONFIG);
MAKE_PIN(P21, CORE_PIN21_PORTREG, CORE_PIN21_BIT, CORE_PIN21_CONFIG);
MAKE_PIN(P22, CORE_PIN22_PORTREG, CORE_PIN22_BIT, CORE_PIN22_CONFIG);
MAKE_PIN(P23, CORE_PIN23_PORTREG, CORE_PIN23_BIT, CORE_PIN23_CONFIG);
MAKE_PIN(P24, CORE_PIN24_PORTREG, CORE_PIN24_BIT, CORE_PIN24_CONFIG);
MAKE_PIN(P25, CORE_PIN25_PORTREG, CORE_PIN25_BIT, CORE_PIN25_CONFIG);
MAKE_PIN(P26, CORE_PIN26_PORTREG, CORE_PIN26_BIT, CORE_PIN26_CONFIG);
MAKE_PIN(P27, CORE_PIN27_PORTREG, CORE_PIN27_BIT, CORE_PIN27_CONFIG);
MAKE_PIN(P28, CORE_PIN28_PORTREG, CORE_PIN28_BIT, CORE_PIN28_CONFIG);
MAKE_PIN(P29, CORE_PIN29_PORTREG, CORE_PIN29_BIT, CORE_PIN29_CONFIG);
MAKE_PIN(P30, CORE_PIN30_PORTREG, CORE_PIN30_BIT, CORE_PIN30_CONFIG);
MAKE_PIN(P31, CORE_PIN31_PORTREG, CORE_PIN31_BIT, CORE_PIN31_CONFIG);
MAKE_PIN(P32, CORE_PIN32_PORTREG, CORE_PIN32_BIT, CORE_PIN32_CONFIG);
MAKE_PIN(P33, CORE_PIN33_PORTREG, CORE_PIN33_BIT, CORE_PIN33_CONFIG);
#undef MAKE_PIN
I'm desperatly trying to find a better library purely for ps3 bluetooth as it seems this library just has everything mashed into 1 folder
