hi,
i have a project that uses arduino nano and and an electromagnet. for this purpose i only had 12v 2a adepter. this is my input. in first prototype i used l298d board which has 5v regulator and there was no problem. now i m designing a pcb card and i cannot use this board because it is not suitable for pcb(if there is a pcb version please tell me) . therefore i dont have any regulator in my design. as a result i need to convert this 12v input to 5v.
i found in arduino nano datasheet :
"The second voltage regulator, the LM1117 supports input voltages between 7V and 12V with a maximum current of 900mA"
my adepter is 12V 2A so is it will be problem for long term in heat ?
if yes, what is your recommendation for my pcb design ? which component should i use?
i am zero experience in this area so i just think that use some regulator + l293d as a motor driver. i m fully open ur recommendations thank you.
thank you
