Arduino no response using SD card and servo motor
Hello, I am creating a program that records altitude and temperature on an SD card using BMP180, SD module, and servo motor, and turns the servo motor when the rocket differs from the maximum altitude by 20m. However, when I run the code, there is no response in the serial monitor and there is no recorded information when I check the SD card. What's the problem?
#include <Servo.h>
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include <time.h>
#include <Adafruit_BMP085.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP085_U.h>
#include <DS1307RTC.h>
Adafruit_BMP085 bmp;
static float altitudemax = 0;
static float altitude = bmp.readAltitude();
File myFile;
Servo servo;
  setSyncProvider(RTC.get);
  setTime(10, 42, 0, 24, 12, 26);
  servo.attach(7);
  Serial.print("Initializing SD card...");
  if (!bmp.begin()) {
    Serial.println("Could not find a valid BMP085 sensor, check wiring!");
    while (1) {}
  if (!SD.begin(4)) {
   // Initialize the SD card module.
    Serial.println("initialization failed!");  //If initialization of the SD card module fails, an error is output.
    while (1);
  Serial.println("initialization done.");
  while (1) {
    // Open the file and prepare it for writing. You can only open one file at a time.
    myFile = SD.open("PRESSURE.txt", FILE_WRITE);  // If there is a second argument, it is in write mode.
    if (myFile) {
      // If the file opens normally, write (add) text to the file.
      Serial.print("Writing to test.txt...");
      myFile.print(year());
      myFile.print("year");
      myFile.print(month());
      myFile.print("month");
      myFile.print(day());
      myFile.print("day");
      myFile.print(hour());
      myFile.print("hour");
      myFile.print(minute());
      myFile.print("minute");
      myFile.print(second());
      myFile.println("second");
      myFile.print("Temperature = ");
      myFile.print(bmp.readTemperature());
      myFile.println(" *C");
      myFile.print("Pressure = ");
      myFile.print(bmp.readPressure());
      myFile.println(" Pa");
      myFile.print("Altitude = ");
      myFile.print(bmp.readAltitude() + 87.5);
      myFile.println(" meters");
      myFile.println();
      myFile.close();
      if (altitude > altitudemax) {
        altitudemax = altitude;
      if (altitudemax - altitude > 20) {
        servo.write(180);
      // If the file cannot be opened, an error is output.
      Serial.println("error opening pressure.txt");
Welcome to the forum
Do you see any output at all in the Serial monitor such as "Initializing SD card..." ?
Arduino and PC were well connected and the correct port was connected. And the result would be the same even if the code was inside a loop function.
No, I couldn't see any messages.
Here is the circuit diagram.
Then what should I do?
The Arduino tutorial linked above suggests to use a 9V battery, which will not work to power a servo. A much better idea is to use a 4xAA battery pack, which also obeys the power supply voltage restrictions for typical servos.
I connected external power but it still doesn't work. However, the Arduino's 'L' LED blinks periodically.
