Arduino Not seeing my if-Else if
Mod edit:
@zxcore every time you post VB .NET (no space) the forum software creates a link to an online shop with that domain name. This makes your post seem like spam. After a lot of consideration I decided that you are not intentionally posting spam. I have gone through your posts and edited each instance of VB .NET to remove the link. Please in future type it with a space.
Thank you.
Needing some Assistance on getting my if-Else if Seeing my Buffers, below is my Code i have, and the screenshot depict the VB .NET application i have written to send the Arduino Numbers i have defined f1 f2 f3 f4 and it is never printing the lines Serial.println("xx received via UDP!"); for various numbers. i only get packetBuffer = 24 anyone help me out. Thanks so much
#include <Ethernet.h>
//DEFINITIONS-----------------------------------------
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED}; //mac adress
IPAddress ip(192, 168, 111, 231); //ip address
unsigned int localPort = 8888; //udp port to listen for packets on
char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
EthernetUDP Udp; //creates Udp instance
char f1 = 10; //char to compare packetBuffer to
char f2 = 44; //char to compare packetBuffer to
char f3 = 60; //char to compare packetBuffer to
char f4 = 24; //char to compare packetBuffer to
  Ethernet.init(10); //sets CS pin for ethernet shield
  Ethernet.begin(mac, ip); //initializes ethernet with mac and ip addresses
  Serial.begin(9600); //initializes serial connection. Waits for serial to be available (native usb only).
  while (!Serial) {
  //Checks for presence of Ethernet shield. Halts if no ethernet hardware present.
  if (Ethernet.hardwareStatus() == EthernetNoHardware) {
    Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
    while (true) {
      delay(1);
  //Checks for presence of etherner link.Halts if no link present.
  if (Ethernet.linkStatus() == LinkOFF) {
    Serial.println("Ethernet cable is not connected.");
  Udp.begin(localPort); //begins udp on port specified above.
  int packetSize = Udp.parsePacket();
  if (packetSize) {                     //if data available, prints following;
    Serial.println("----------------------------------------------");
    Serial.print("Received packet of size ");
    Serial.println(packetSize);
    Serial.print("From ");
    IPAddress remote = Udp.remoteIP();
    for (int i = 0; i < 4; i++) {
      Serial.print(remote[i], DEC);
      if (i < 3) {
        Serial.print(".");
    Serial.print(", port ");
    Serial.println(Udp.remotePort());
    Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
    Serial.print("packetBuffer = ");
    Serial.println(packetBuffer);
    if (packetBuffer[0] == f1) {
      Serial.println("Contents:"); //10
      Serial.println("10 received via UDP!");
    } else if(packetBuffer[0] == f2) {
      Serial.println("Contents"); //44
      Serial.println("44 received via UDP!");
    } else if (packetBuffer[0] == f3) {
      Serial.println("Contents"); //60
      Serial.println("60 received via UDP!");
    } else if (packetBuffer[0] == f4) {
      Serial.println("Contents"); //24
      Serial.println("24 received via UDP!");
      Serial.println("60 received via UDP!");// Serial.println("SOMETHING WENT WRONG");
    Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
    Udp.write("acknowledged", 13);
    Udp.flush();
    Udp.endPacket();
Is your sending code issuing one byte with the value of 24 or is it sending the
character string "24", that is, two bytes with ascii values for '2' and '4'?
Your packetBuffer contains 50, 52, and 0 so, as a character string, it prints out "24" (50 is the ASCII code for '2' and 52 is the ASCII code for '4'). If you want to match against character strings:
char f1[] = "10"; //char string to compare packetBuffer to
char f2[] = "44"; //char string to compare packetBuffer to
char f3[] = "60"; //char string to compare packetBuffer to
char f4[] = "24"; //char string to compare packetBuffer to
    if (strcmp(packetBuffer, f1) == 0) {
And similar for the other three strings
