did anyone here had worked with the arduino and wii nunchuck connected to it?
im new to arduino, and i am working with a project. and i need the nunchuck to communicate with the arduino. can you help me with the code???
thanks
Sure. See that search button up there? No? Well look closer. Found it? Good. Type stuff in there. Hit the button.
There have been lots of people posting about using the Wii Nunchuck with the Arduino. Some even were successful.
What would you like it do? Tell the Arduino bedtime stories? Sing it lullabies?
i want to read the data that the arduino will give in x, y, z then if a certain value of the accel x, accel y and accel z was read by the arduino from the nunchuck the arduino will output logic one on its output pin or pins.. something like that... i already used some code that came from the net and when i connect the nunchuck controller, it just stops transmitting, therefore it doesn't blinks ttx led, nor prints on the serial port monitor. the arduino just print accel: 0,0,0 if i disconnected the nunchuck...
here's the link of the code i used...
http://www.windmeadow.com/node/42
