Arduino oddly waking from gsm message
Hi everyone,
I'm playing with a gsm module (sim800L) and noticed a 'strange' thing happening while trying to put the arduino to sleep and handling a message received. What happens is that I put the arduino to sleep, it goes sleeping (using LowPower lib) but it wakes if it receives a message through the sim800 module. How is this happening, since I dont have any interrupt pins from the gsm to arduino, only GND, TX, RX ?
I known that the GPRS_Shield_Arduino library is using SoftwareSerial, but in which way could the SoftwareSerial wake the arduino ?
GPRS_Shield_Arduino Library link
#include <GPRS_Shield_Arduino.h>
#include <SoftwareSerial.h>
#include <LowPower.h>
#define PIN_TX    7
#define PIN_RX    8
#define BAUDRATE  9600
#define MESSAGE_LENGTH 160
char message[MESSAGE_LENGTH];
int messageIndex = 0;
char phone[16];
char datetime[24];
GPRS gprsTest(PIN_TX, PIN_RX, BAUDRATE); //RX,TX,PWR,BaudRate
#define LED 13
  pinMode(LED, OUTPUT);
  digitalWrite(LED, LOW);
  while (!gprsTest.init())
    Serial.print("init error\r\n");
  delay(3000);
  Serial.println("Init Success, please send SMS message to me!");
  sleep();
  readsms();
void readsms()
  messageIndex = gprsTest.isSMSunread();
  if (messageIndex > 0) //At least, there is one UNREAD SMS
    gprsTest.readSMS(messageIndex, message, MESSAGE_LENGTH, phone, datetime);
    //In order not to full SIM Memory, is better to delete it
    digitalWrite(LED, HIGH); //some visual indication that I received a message
    delay(3000);
    gprsTest.deleteSMS(messageIndex);
    Serial.print("From number: ");
    Serial.println(phone);
    Serial.print("Datetime: ");
    Serial.println(datetime);
    Serial.print("Recieved Message: ");
    Serial.println(message);
void sleep()
  LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
SoftwareSerial uses a pin change interrupt. That will wake the processor.
thank you for clarifying it :slight_smile:
How would one then avoid it reading the message if it's sleeping ?
Disable it somehow. I don't know what library you're using but there must be some way to shut it off. Or you can do it directly by calling the SoftwareSerial stopListening() method.
that did the job :smiley: yay thanks!
