Hello guys!
I'm a newbie in the Arduino world, and I made a choice I'm starting to regret: building my arduino on a breadboard.
I bought 2 AtMega328 preloaded with bootloader and a USB to Serial with FT232R chip, and followed the standalone instructions from http://arduino.cc/en/Main/Standalone
I also added the autoreset feature by using a 0.1uF capacitor between DTR and reset pin of the AtMega328.
After setting all up, the led connected to PB5 (arduino pin 13) blinks.
The problem is that I can't get a connection between the Arduino IDE and the atmega, neither using the manual switch to reset nor the autoreset. Also this happens with both the AtMega328.
WITH UBUNTU 10.04
Fresh install, unistalled brltty and installed the arduino package from the ppa as stated in the ubuntu instructions.
This is what happens:
Binary sketch size: 896 bytes (of a 30720 byte maximum)
avrdude -v -v -v -v -patmega328p -carduino -P/dev/ttyUSB0 -b57600 -D -Uflash:w:/tmp/build7017198197249163195.tmp/Blink.cpp.hex:i
avrdude: Version 5.10, compiled on Mar 23 2010 at 15:03:00
Copyright (c) 2000-2005 Brian Dean
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/home/ubuntu/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
avrdude done. Thank you.
WITH VISTA
Installed the newest ftdi drivers from the website. Donwloaded latest arduino (0019). Disabled antivirus and firewall.
This is what happens every time:
avrdude: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
System wide configuration file is "C:\Users\...\arduino-0019\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM3
Using Programmer : stk500v1
avrdude: ser_open(): setting dtr
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: Send: Q [51] [20]
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
I tried everything i could find in the forum, but without success. (yeah, the port is the right one, and i tried all the possible boards)
Does someone have any advice?
Thank you!!!
Gabriele
