MacOS Ventura 13.6.2 on M2 silicon.
I have an OV7670 board connected to Arduino Nano 33 BLE Sense. I communicate with the Arduino over /dev/tty.usbmodem1101 (aka /dev/cu.usbmodem1101.)
Python (using colab) returns "No such file or directory: '/dev/tty.usbmodem1101'" when I try to open the serial port.
I have a pushbutton that the Arduino code is polling for, so I can tell that the serial port is still open/functional.
I tried multiple ports on the Mac just in case one has some limited capabilities, but they all return the same message.
What am I missing here?
If you have opened the serial monitor the serial monitor in the arduino-ide the IDE occupies the port.
Hence other software can't use it.
I closed the IDE and re-opened/re-compiled without opening the serial monitor. I still see the same error message. If it told me the port was in use, I think that might be the answer, but it can't find it at all.
From command line:
MacBook-Pro-5:~ xxx$ python -m serial.tools.list_ports
/dev/cu.Bluetooth-Incoming-Port
/dev/cu.GalaxyBudsLiveEEBF
Inside python:
import serial.tools.list_ports
ports = serial.tools.list_ports.comports()
for p in ports:
print(p.device)
print(len(ports), 'ports found')
returns: "0 ports found"
Unclear why there would be inconsistency between the two.
Anyways, I ran this in PyCharm and it worked. No idea what's wrong with colab.
system
Closed
June 29, 2024, 2:58am
5
