Arduino Opta - Unable to Communicate via PLC IDE
I recently purchased an Arduino Opta Wifi device. I'm able to connect the device to my PC and download the Bootloader to device from the Arduino PLC IDE. It recognizes the device connection on a COM port that I can view from Device Manager on my PC. However, once I download the Bootloader, I'm only able to see one COM port connection. I'm unable to connect to the device from the PLC IDE program because there is no additional COM port available to configure Modbus communications to.
I've attempted to:
  • Reboot my PC (multiple times)
  • Factory reset the Arduino Opta device and re-download the Bootloader
  • Tested multiple usb-c ports on my PC
  • Uninstall and re-install the PLC IDE and PLC IDE Tools software (did this after disabling Firewall on PC and running the .exe as Administrator)
  • Re-flashing the opta memory partition with the Arduino sketch file provided on the Arduino website.
I'm able to connect to the regular Arduino IDE and upload sketches to the Opta device, multiple uploaded programs have functioned properly on the device. I need to be able to program with the PLC IDE software for my purposes. Please let me know if anyone has seen this issue, or knows of another workaround I haven't tested.
Thanks
Hello,
Thank you for posting your issue. Please try again by carefully following the steps below:
First, open the Arduino IDE and follow these steps:
  • Go to File > Examples > STM32H747_System > QSPIFormat.
  • Make sure the Opta is selected as the target board.
  • Upload the sketch to your Opta.
Once the upload is complete:
  • Open the Serial Monitor.
  • When prompted, reply with “y” to all four questions.
  • It is important that the memory is formatted using LittleFS, as this is required for the Opta to work correctly with Arduino PLC IDE.
After the formatting process finishes, press the Reset button once to reboot the Opta.
Then completely close the Arduino IDE and open the Arduino PLC IDE. Please make sure you are using the latest version of PLC IDE (currently 1.1.0), which you can download from the following link: https://www.arduino.cc/en/software/#arduino-plc-ide
In PLC IDE, follow these steps:
  • Create a new project with any name of your choice.
  • From the “Other” section, click Download to upload the Runtime to your board (ensure the correct COM port is selected).
  • Once the Runtime upload is complete, go to Project > Refresh current target and confirm with Yes.
  • Then go to Online > Set up communication, select the appropriate port, and confirm.
  • Finally, go to Online > Connect.
  • If the connection is successful, activate the PLC Runtime.
Please let me know if this procedure allows to connect successfully afterward.
Best regards,
I seem to have the same problem. I can flash anything from bootloader in Arduino IDE, than after initializing runtime in PLC IDE I can't connect anymore through PLCE IDE, latest versions and everything. Also here only one COM port.
I want to take a moment to say thank you. I've been pulling my hair out having issues connecting my Opta Wifi to the PLC IDE. Same issues as the OP. I followed these steps, and this worked for me. I just about cried when I saw the green "Connected"!!
THANK you so much.
