arduino pop168 -popbot help plzzzzzz
i am trying to make a vrbot ....so any one who owns a arduino pop 168(popbot)...can u provide me with its sample coding
as am using servos for tires and a serial lcd will this code work
#if defined(ARDUINO) && ARDUINO >= 100
  #include "Arduino.h"
  #include "SoftwareSerial.h"
  SoftwareSerial port(12,13);
#else // Arduino 0022 - use modified NewSoftSerial
  #include "WProgram.h"
  #include "NewSoftSerial.h"
  NewSoftSerial port(12,13);
#endif
#include "EasyVR.h"
EasyVR easyvr(port);
int8_t set = 0;
int8_t group = 0;
uint32_t mask = 0;
uint8_t train = 0;
char name[32];
bool useCommands = true;
EasyVRBridge bridge;
  // bridge mode?
  if (bridge.check())
    cli();
    bridge.loop(0, 1, 12, 13);
  // run normally
  port.begin(9600);
  if (!easyvr.detect())
    Serial.println("EasyVR not detected!");
    for (;;);
  easyvr.setPinOutput(EasyVR::IO1, LOW);
  Serial.println("EasyVR detected!");
  easyvr.setTimeout(5);
  easyvr.setLanguage(EasyVR::ITALIAN);
  int16_t count = 0;
  Serial.print("Sound table: ");
  if (easyvr.dumpSoundTable(name, count))
    Serial.println(name);
    Serial.print("Sound entries: ");
    Serial.println(count);
    Serial.println("n/a");
  if (easyvr.getGroupMask(mask))
    uint32_t msk = mask;
    for (group = 0; group <= EasyVR::PASSWORD; ++group, msk >>= 1)
      if (!(msk & 1)) continue;
      if (group == EasyVR::TRIGGER)
        Serial.print("Trigger: ");
      else if (group == EasyVR::PASSWORD)
        Serial.print("Password: ");
        Serial.print("Group ");
        Serial.print(group);
        Serial.print(": ");
      count = easyvr.getCommandCount(group);
      for (int8_t idx = 0; idx < count; ++idx)
        if (easyvr.dumpCommand(group, idx, name, train))
          Serial.print(idx);
          Serial.print(" = ");
          Serial.print(name);
          Serial.print(", Trained ");
          Serial.print(train, DEC);
          if (!easyvr.isConflict())
            Serial.println(" times, OK");
            int8_t confl = easyvr.getWord();
            if (confl >= 0)
              Serial.print(" times, Similar to Word ");
              confl = easyvr.getCommand();
              Serial.print(" times, Similar to Command ");
            Serial.println(confl);
  group = 0;
  mask |= 1; // force to use trigger
  useCommands = (mask != 1);
const char* ws0[] =
  "ROBOT",
const char* ws1[] =
  "ACTION",
  "MOVE",
  "TURN",
  "RUN",
  "LOOK",
  "ATTACK",
  "STOP",
  "HELLO",
const char* ws2[] =
  "LEFT",
  "RIGHT",
  "UP",
  "DOWN",
  "FORWARD",
  "BACKWARD",
const char* ws3[] =
  "ZERO",
  "ONE",
  "TWO",
  "THREE",
  "FOUR",
  "FIVE",
  "SIX",
  "SEVEN",
  "EIGHT",
  "NINE",
  "TEN",
const char** ws[] = { ws0, ws1, ws2, ws3 };
bool checkMonitorInput()
  if (Serial.available() <= 0)
    return false;
  // check console commands
  int16_t rx = Serial.read();
  if (rx == 'b')
    useCommands = false;
    set++;
    if (set > 3)
      set = 0;
  if (rx == 'c')
    useCommands = true;
    do
      group++;
      if (group > EasyVR::PASSWORD)
        group = 0;
    } while (!((mask >> group) & 1));
  if (rx == 's')
    int16_t num = 0;
    delay(5);
    while ((rx = Serial.read()) >= 0)
      if (isdigit(rx))
        num = num * 10 + (rx - '0');
      delay(5);
    if (rx == '.')
      easyvr.stop();
      easyvr.playSound(num, EasyVR::VOL_DOUBLE);
  if (rx >= 0)
    easyvr.stop();
    Serial.flush();
    return true;
  return false;
  checkMonitorInput();
  easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
  if (useCommands)
    Serial.print("Say a command in Group ");
    Serial.println(group);
    easyvr.recognizeCommand(group);
    Serial.print("Say a word in Wordset ");
    Serial.println(set);
    easyvr.recognizeWord(set);
  do
    if (checkMonitorInput())
      return;
  while (!easyvr.hasFinished());
  easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
  int16_t idx = easyvr.getWord();
  if (idx >= 0)
    Serial.print("Word: ");
    Serial.print(easyvr.getWord());
    if (useCommands)
      Serial.println(ws[group][idx]);
      Serial.println(ws[set][idx]);
    // ok, let's try another set
    set++;
    if (set > 3)
      set = 0;
    easyvr.playSound(0, EasyVR::VOL_FULL);
    idx = easyvr.getCommand();
    if (idx >= 0)
      Serial.print("Command: ");
      Serial.print(easyvr.getCommand());
      // ok, let's try another group
      do
        group++;
          group = 0;
    else // errors or timeout
      if (easyvr.isTimeout())
        Serial.println("Timed out, try again...");
      int16_t err = easyvr.getError();
      if (err >= 0)
        Serial.print("Error ");
        Serial.println(err, HEX);
Moderator edit: CODE TAGS. Don't use servos as tyres, they have square edges and don't roll well.
:frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning:
will this code work
Probably not.
#endif
You are creating an object names port that is of one of two different types.
Is the EasyVR constructor overloaded to be able to take either type?
    cli();
Why are you mucking with interrupts?
You are the one with the hardware. Does the program compile? Can you upload it? Does it do what you want?
any one can supply me with a simple code to move both servos forward and backward using vrbot moduel :fearful:
help me out :drooling_face:
Have you tried any of the sketches in the user manual?
i tried this 1 but here they have used motors i am using servos void setup(){
pinMode(3,OUTPUT); // Motor A1
pinMode(5,OUTPUT); // Motor A2
pinMode(6,OUTPUT); // Motor B2
pinMode(9,OUTPUT); // Motor B1
void Forward(){ // Robo-Spinner Go Forward Rountine
digitalWrite(3,HIGH);
digitalWrite(5,LOW);
digitalWrite(6,HIGH);
digitalWrite(9,LOW);
void Backward(){ // Robo-Spinner Go Backward Rountine
digitalWrite(3,LOW);
digitalWrite(5,HIGH);
digitalWrite(6,LOW);
digitalWrite(9,HIGH);
void loop(){
Forward();
Backward();
and who to make it work with vr thats the prob
You'll want the servo library then: Servo - Arduino Reference
any what about voice recogination moduel
There is a library download and a demo sketch at http://www.veear.eu/Products/EasyVR.aspx. I don't have an EasyVR, so I can't test it, but you do, so you can.
