Arduino Powered Robot
This is my first attempt at a robot. I started off with a Arduino Robot Kit from robotshop.com and modified it a bit from there.
I used a Parallax Ping Ultrasound sensor connected to panning servo that rotates through 70 degrees. If the sensor detects an object within 3 cm, the avoidance subroutine kicks in and the robot with move around the object and continue on course. There is also an 2 axis accelerometer/tilt sensor. If the robot tilts more than 10 degrees in the x or y direction, the avoidance subroutine kicks in.
Attached to the Arduino is a Sparkfun Xbee shield. Attached to my laptop is a Parallax USB xbee adapter. If the robot gets into trouble that it can't get out of, the operator can toggle remote mode by cycling a button on the remote controller. The wireless unit uses two Xbee Series 1 modules.
  1. First Press issues an all stop command
  2. Second press trigger remote control mode. Robot can be controlled using serial interface and keyboard commands.
  3. Third press returns the robot to autonomous mode.
Also in work is a web interface for remote control mode. Currently, the robot can be (forward, reverse, left, right and stop buttons work) using the interface. What doesn't work (yet) is the toggle from autonomous mode to remote mode. I haven't quite got the php and arduino code figured out for that.
Coming up next is integration of a small wireless camera that will stream images to the webpage for true remote control operation.
Thanks for looking.
The accelerometer can be seen here (small green PCB)
The Xbee Shield and the Pololu dual serial motor controller (green pcb sticking up)
Xbee remote control with toggle mode button
Web interface
Very good!
post some videos if possible and share your source code.
So other can take some ideas.
Thanks.
Thanks
Video coming tonight. I needed to charge my batteries.
:slight_smile:
Except for a few tweaks, here is the source code.
#include <FiniteStateMachine.h>
#include <NewSoftSerial.h>
#include <Servo2.h>
#include <TimedAction.h>
#include <math.h>
NewSoftSerial mySerial(4, 3);  //int rx, int tx)
//config timing
const byte NUMBER_OF_SCANS_PER_SECOND = 2;  //change this to suit your needs
const byte SCAN_FREQUENCY = 1000/NUMBER_OF_SCANS_PER_SECOND;
//TimedAction / 'thread' objects
TimedAction scanAction = TimedAction(SCAN_FREQUENCY,scan);
const byte NUMBER_OF_STATES = 3;
int motor_reset = 12;  //motor reset pin
int pingPin = 7;  //ping sensor pin
int ledpin = 8; //led warning pin
int xPin = 5;
int yPin = 6;
long echo = 0;
int distance = 0;  //set distance to zero
long tilt = 0;      //set tilt angle to zero
//initialize states
State remote = State(remoteOn);
State automatic = State(autoOn);
State allstop = State(motorstop);
FSM autoStateMachine = FSM(automatic);  //start in automatic mode
int switchPin = 11;
Servo myservo;  // create servo object to control a servo
int servoPosition = 10;       //start position
boolean scanIncrement = true;  //increase position?
byte servoIncrementValue = 5;
byte servoDecrementValue = 5;
int Xraw, Yraw;
double xGForce, yGForce, Xangle, Yangle;
int val;
int buttonState;
int mode = 0;  //0 = auto mode, 1 = stop mode, 2 = remote mode (yeah, it's confusing but it's my code :)
  pinMode(motor_reset, OUTPUT);  //motor reset pin
  mySerial.begin(9600);
  digitalWrite(motor_reset, LOW);
  delay(50);
  digitalWrite(motor_reset, HIGH);
  delay(50);
  pinMode(switchPin, INPUT);
  buttonState = digitalRead(switchPin);
  mySerial.begin(9600);    //start software serial communication
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  pinMode(yPin, INPUT); //read values from y axis pin
  pinMode(xPin, INPUT); //read values from x axis pin
void loop () {
  val = digitalRead(switchPin);
  if (val != buttonState) {          // the button state has changed!
    if (val == LOW) {                // check if the button is pressed
      if (mode == 0) {            // auto mode on?
        mode = 1;              //change to stop mode
        autoStateMachine.transitionTo(allstop);  //all stop
      else {
        if (mode == 1) {  // if it is stopped
          mode = 2;
          autoStateMachine.transitionTo(remote); //change to remote
        else {
          if (mode == 2) {  // if it is in remote mode
            mode = 0;        //auto mode on
            autoStateMachine.transitionTo(automatic);   //change to auto
  buttonState = val;
  //Serial.println(val);
  //Serial.println(mode);
  autoStateMachine.update();
void remoteOn() {  //remote stuff - this works
  if (Serial.available() > 0) {
    int inByte = Serial.read();
    switch (inByte) {
    case 'w':
      motorforward();
    case 's':
      motorreverse();
    case 'd':
      rotateccw();
    case 'a':
      rotatecw();
    default:
      motorstop();
void autoOn() {  //simple auto mode for now
  scanAction.check();
void scan()
  scanIncrement ? servoPosition+=servoIncrementValue : servoPosition-=servoDecrementValue; //increment or decrement current position
  if (servoPosition > 70){
    scanIncrement = false;
    servoPosition = 70;
  else if (servoPosition < 10){
    servoPosition = 10;
  motorforward();
  myservo.write(servoPosition);
  long distance = ping();
  long tilt = angle();
long ping() {
  pinMode(pingPin, OUTPUT); // Switch signalpin to output
  digitalWrite(pingPin, LOW); // Send low pulse
  delayMicroseconds(2); // Wait for 2 microseconds
  digitalWrite(pingPin, HIGH); // Send high pulse
  delayMicroseconds(5); // Wait for 5 microseconds
  digitalWrite(pingPin, LOW); // Holdoff
  pinMode(pingPin, INPUT); // Switch signalpin to input
  digitalWrite(pingPin, HIGH); // Turn on pullup resistor
  echo = pulseIn(pingPin, HIGH); //Listen for echo
  distance = (echo / 58.138) * .39; //convert to CM then to inches
  //Serial.println(distance);
  if (distance <= 3 && distance !=0) //need the !=0 to filter some false zero values
    avoid();
//start tilt check
long angle() {
  Xraw = pulseIn (xPin, HIGH);
  Yraw = pulseIn (yPin, HIGH);
  // Calculate G-force in Milli-g's.
  xGForce = (( Xraw / 10 ) - 500) * 8;
  yGForce = (( Yraw / 10 ) - 500) * 8;
  // uncomment next four lines for milli-g output.
  //Serial.println(xGForce);
  //Serial.print(" ");
  //Serial.println(yGForce);
  // Calculate angle (radians) for both -x and -y axis.
  Xangle = asin ( xGForce / 1000.0 );
  Yangle = asin ( yGForce / 1000.0 );
  // Convert radians to degrees.
  Xangle = Xangle * (360 / (2*M_PI));
  Yangle = Yangle * (360 / (2*M_PI));
  if (Xangle >= 10 || Yangle >= 10 || Yangle <= -10)
    avoid();
  //Serial.println(Xangle);
  //Serial.println(Yangle);
//avoid subroutine
void avoid()
  motorstop();
  ledwarning();
  motorreverse();
  delay(2000);
  motorstop();
  rotateccw();
  motorstop();
  motorforward();
  motorstop();
  rotatecw();
  motorstop();
//fire the led pin as a warning
void ledwarning()
  digitalWrite(ledpin, HIGH);
  digitalWrite(ledpin, LOW);
//subroutine motor forward
void motorforward()
  //left motor
  unsigned char buff1[6];
  buff1[0] = 0x80;  //start byte - do not change
  buff1[1] = 0x00;  //device type byte - do not change
  buff1[2] = 0x01; //Motore number and direction byte;  motor one = 00,01
  buff1[3] = 0x7F; //Motor speed "0 to 127" in hex
  for(int i=0;i<4;i++) {
    mySerial.print(buff1[i], BYTE);
  //right motor
  unsigned char buff2[6];
  buff2[0] = 0x80;  //start byte - do not change
  buff2[1] = 0x00;  //device type byte - do not change
  buff2[2] = 0x03; //Motore number and direction byte;  motor two = 02,03
  buff2[3] = 0x7F; //Motor speed "0 to 127" in hex
    mySerial.print(buff2[i], BYTE);
//subroutine motor reverse
void motorreverse()
  //left motor
  unsigned char buff3[6];
  buff3[0] = 0x80;  //start byte - do not change
  buff3[1] = 0x00;  //device type byte - do not change
  buff3[2] = 0x00; //Motore number and direction byte;  motor one = 00,01
  buff3[3] = 0x46; //Motor speed "0 to 127" in hex
    mySerial.print(buff3[i], BYTE);
  //right motor
  unsigned char buff4[6];
  buff4[0] = 0x80;  //start byte - do not change
  buff4[1] = 0x00;  //device type byte - do not change
  buff4[2] = 0x02; //Motore number and direction byte;  motor two = 02,03
  buff4[3] = 0x46; //Motor speed "0 to 127" in hex
    mySerial.print(buff4[i], BYTE);
  //subroutine motor all stop
void motorstop()
  //left motor
  buff3[3] = 0x00; //Motor speed "0 to 128" in hex
  //right motor
  buff4[3] = 0x00; //Motor speed "0 to 128" in hex
void rotateccw()
  //left motor
  buff3[2] = 0x01; //Motore number and direction byte;  motor one = 00,01
  buff3[3] = 0x40; //Motor speed "0 to 127" in hex
  //right motor
  buff4[3] = 0x40; //Motor speed "0 to 127" in hex
void rotatecw()
  //left motor
  //right motor
  buff4[2] = 0x03; //Motore number and direction byte;  motor two = 02,03
cool!!
Waiting to see the video!
Nice project!
Ok here is the video. A bit rough but you can see it starting in auto mode and going around the box. I then toggle it to remote mode and move it around remotely. Sorry for the background noise my infant son was being fussy :slight_smile: ugh and it"s sideways. i'll try and shoot some better video tomorrow
What about the web interface ?
Can you share code ? Or where were your based of ?
This is very nice. I'm building something similar with Tamiya tracks, Tamiya motors and a cardboard frame. It's a lot flimsier than yours, but also a lot cheaper.
