Arduino Pro Micro NRF24L01
Hello, I am using the RadioHead library with an Arduino Pro Micro to make two nrf24l01 transceivers talk to one another. The problem is that when I startup my sketch, it says Init Failed.
Does anyone have experience working with the RadioHead library on the Pro Micro?
I have attached a picture of my schematic. The SDA and SCL will go to a Gyro module not currently attached.
The Pro Micro uses the same chip as the Uno, it won't be Pro-Micro specific unless its inadequate
3.3V power causing the problem.
Image from Original Post so we don't have to download it. See this Image Guide
...R
My Pro Micro uses the 32U4 MCU.
I have not tried to get my nRF24s working with the Pro Micro but I had no trouble with my Leonardo which also uses the 32U4.
I have only used TMRh20's RF24 library as in this Simple nRF24L01+ Tutorial
Your diagram does not show any connection to CSN
You have not posted your program.
...R
