Arduino Pro Micro Powers On, Windows 11 doesn't recognize it
I'm new to Arduino and I have been trying to make a simple switching program triggered by a motion sensor. It has not been easy.
Most recently, I fried my Arduino Nano that I was using. Not sure how.
I have an Arduino UNO that often won't take a new sketch and does nothing, an Arduino Pro with no USB header, making it useless to me, and a Arduino Micro Pro that I am hoping to use for this simple simple project.
I can't get the Micro Pro to trigger Windows and assign a com port. So I can't access it in the IDE. Any suggestions? So far the only similar issue I have found was someone who had a bad cable. I've tried 3 different Windows 11 machines and 6 different cables. The device powers on and a green LED stays solid. Meanwhile the red LED blinks. I read that the blinking red LED is the default "BLINK" sketch loaded into new Arduinos.
Anyone know how to get Windows to acknowledge my Micro Pro? Thanks for your help.
One would guess that either:
  1. There are no windows drivers for the device.
  2. Windows 11 has some sort of protection blocking recognizing the device.
  • Is the Arduino IDE installed?
  • Have you been able to have Win 11 recognize any Arduino board?
  • You should look at "device manager" to see if there are any devices connected that windows 11 doesn't know what to do with.
Because there are a number of devices you should take a screenshot before and when the device is connected.
It should show here at the red arrow but if Windows doesn't know what to do with it it could be in the blue circle.
The Pro Micro uses a microUSB cable. MicroUSB cables come in two flavours, charge only cables and data cables (sync cables). I suspect that you are using a charge-only cable.
Try other cables or buy a sync cable. If you have a phone that has a microUSB port, use the cable that came with it for data transfer between your PC and the phone.
Thanks for your reply. I am using the same micro usb cable that I have been using to transfer data between a couple of external hd enclosures, so it is definitely not a power cable. That was a reasonable suggestion, but I have tried other cables as well and nothing seems to get it to recognize. This is the Event Log Error:
Device USB\VID_0000&PID_0002\7&c9239dc&0&4 had a problem starting.
Driver Name: usb.inf
Class Guid: {36fc9e60-c465-11cf-8056-444553540000}
Service:
Lower Filters:
Upper Filters:
Problem: 0x2B
Problem Status: 0x0
additional info in event log:
Device USB\VID_0000&PID_0002\7&c9239dc&0&4 was configured.
Driver Date: 06/21/2006
Driver Version: 10.0.22000.918
Driver Provider: Microsoft
Driver Section: BADDEVICE.Dev.NT
Driver Rank: 0xFF0000
Matching Device Id: USB\DEVICE_DESCRIPTOR_FAILURE
Outranked Drivers: usb.inf:USB\DEVICE_DESCRIPTOR_FAILURE:00FF2000
Device Updated: false
It seems like these are not very hearty little devices and the boot loaders go bad a lot. Perhaps that's the problem. I just don't know what to do about it. Thanks for any advice you may have
I can definitely see the device in the Device Manager and see the errors it has in the event log. It's not getting a descriptor from the device and assigning it "bad device" drivers while disabling it.
It appears to be a driver problem. What version of the IDE are you using? I've read some old posts that suggest the 1.8x version might help but I can't attest to that. I don't have Win11 or a Pro Micro.
The VID and PID look odd to me but i can not check at the moment. I use original Sparkfun ProMicros (3.3V / 8MHz) so will check later when load shedding and time permit. I usually don't dig in the event log; can you point me to the correct location?
That is very unlikely. The usual cause is bugs in the sketch that corrupt variables used by the CDC stack that is part of the uploaded sketch. This results in the device not being detected or not reacting on the software reset.
//Edit
This applies to all devices with native USB; Leonardo, Micro, newer Arduino boards (e.g. Nano 33 ..., MKR...) and 3rd party boards).
One more thing. Sparkfun has a boards package for their boards. If you haven't installed it yet, it might be worth a try.
FYI: the VID / PID of a 3.3V / 8MHz ProMicro is 1BF4 / 9204 in my system. I don't have reason to believe that the 5V / 16MHz version differs.
Checked on Windows 10.
