ciao a tutti! mi trovo in fase di stop ahahaha. comunque, non riesco a far lavorare assieme arduino e processing, vorrei girare un servo, ho provato con il mouse e sono riuscito, ma con un altro apparecchio non riesco. in arduino ho messo esempi-firmata-standardfirmata. e in processing il codice che metto qui sotto..ps: il servo è collegato al pin digitale 9
// import the fingertracker library
// and the SimpleOpenNI library for Kinect access
import fingertracker.*;
import SimpleOpenNI.*;
// declare FignerTracker and SimpleOpenNI objects
FingerTracker fingers;
SimpleOpenNI kinect;
// set a default threshold distance:
// 625 corresponds to about 2-3 feet from the Kinect
int threshold = 625;
size(640, 480);
// initialize your SimpleOpenNI object
// and set it up to access the depth image
kinect = new SimpleOpenNI(this);
kinect.enableDepth();
// mirror the depth image so that it is more natural
kinect.setMirror(true);
// initialize the FingerTracker object
// with the height and width of the Kinect
// depth image
fingers = new FingerTracker(this, 640, 480);
// the "melt factor" smooths out the contour
// making the finger tracking more robust
// especially at short distances
// farther away you may want a lower number
fingers.setMeltFactor(100);
void draw() {
// get new depth data from the kinect
kinect.update();
// get a depth image and display it
PImage depthImage = kinect.depthImage();
image(depthImage, 0, 0);
// update the depth threshold beyond which
// we'll look for fingers
fingers.setThreshold(threshold);
// access the "depth map" from the Kinect
// this is an array of ints with the full-resolution
// depth data (i.e. 500-2047 instead of 0-255)
// pass that data to our FingerTracker
int[] depthMap = kinect.depthMap();
fingers.update(depthMap);
// iterate over all the contours found
// and display each of them with a green line
stroke(0,255,0);
for (int k = 0; k < fingers.getNumContours(); k++) {
fingers.drawContour(k);
// iterate over all the fingers found
// and draw them as a red circle
noStroke();
fill(255,0,0);
for (int i = 0; i < fingers.getNumFingers(); i++) {
PVector position = fingers.getFinger(i);
ellipse(position.x - 5, position.y -5, 10, 10);
// show the threshold on the screen
fill(255,0,0);
text(threshold, 10, 20);
// keyPressed event:
// pressing the '-' key lowers the threshold by 10
// pressing the '+/=' key increases it by 10
void keyPressed(){
if(key == '-'){
threshold -= 10;
if(key == '='){
threshold += 10;
