Hello, I was doing Project 6 of the Arduino Uno starter kit and the Phototransistor did not seem to pick up any signals and the Piezo would simply buzz without any change.
Is this a known issue? could it have something to do with my code? or is my wiring wrong?
int sensorValue;
int sensorLow = 1023;
int sensorHigh = 0;
const int ledPin = 13;
// put your setup code here, to run once
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, HIGH);
while (millis() > 5000) {
sensorValue = analogRead(A0);
if (sensorValue > sensorValue) {
sensorHigh = sensorValue;
if (sensorValue < sensorLow)
sensorLow = sensorValue;
digitalWrite(ledPin, LOW);
int pitch =
map(sensorValue, sensorLow, sensorHigh, 50, 4000);
tone(8, pitch, 20);
delay (10);
Welcome to the forum, and good job with the code tags on your first post.
The brackets in your code are in the wrong place, and the sensor is not being calibrated. You are reading the sensor for 5 seconds, but with the misplaced brackets, you don't actually assign the values to max and min.
See this correct code from the tutorial
https://create.arduino.cc/projecthub/SBR/light-theremin-c28a1d
Arduino Starter Kit example
Project 6 - Light Theremin
This sketch is written to accompany Project 6 in the Arduino Starter Kit
Parts required:
- photoresistor
- 10 kilohm resistor
- piezo
created 13 Sep 2012
by Scott Fitzgerald
https://store.arduino.cc/genuino-starter-kit
This example code is part of the public domain.
// variable to hold sensor value
int sensorValue;
// variable to calibrate low value
// variable to calibrate high value
int sensorHigh = 0;
// LED pin
// Make the LED pin an output and turn it on
// calibrate for the first five seconds after program runs
while (millis() < 5000) {
// record the maximum sensor value
if (sensorValue > sensorHigh) {
// record the minimum sensor value
if (sensorValue < sensorLow) {
// turn the LED off, signaling the end of the calibration period
//read the input from A0 and store it in a variable
// map the sensor values to a wide range of pitches
int pitch = map(sensorValue, sensorLow, sensorHigh, 50, 4000);
// play the tone for 20 ms on pin 8
tone(8, pitch, 20);
// wait for a moment
delay(10);
Thanks for the Assistance!
This worked! Thank you very much!
