How easy it is depends on your receiver. If you can access to the composite data stream from the receiver than you can decode the signal using a library discussed in this thread. http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1228137503
Decoding servo pulses on each pin is possible but quite difficult. The approach discussed in that thread uses the combined signal of all the servo pulses, but the Arduino decodes the signals rather than the receiver.
This project isn't easy - there is no beginners tutorial to make everything simple. I suggest you read through that rather long thread and see if it makes sense to you.
Not sure what to recommend for the arduino baord. The code was written before the mega existed so I have only run it on a standard arduino board. The Mega has more timers so it may be possible to use the standard arduino library and the ServoDecode library together - but the pin numbers will be different and it would need some additional research on your part.
Why not read through the thread and see if its something you want to tackle.
Ok I'have read a bit the discussion...even if my English isn't perfect I think I have understand that that program read the signal from only one pin and devides it in all the 8 signals sent from the transmitter...I'm right?
To use that method I must be shure that the receiver can send a signal with all the commands on a single output...how can I check it? All the receivers can send that type of message?
For my project at the beginning I suppose to use four different output of the receiver connected to four different digital pins of the board...can I use this method? Is it possible with 2009?
Infact I found an exaple using this method...but in this project the author needed only 2 pin because he used only 2 commands from the receiver...and to read this signals he used Arduino2009 pin 2&3 that are called "External Interrupts"...but I need 4 input like this...
I think that if someone can give me a link where is explained how rc receivers works I can solve a lot of my problems...
Most conventional (non digital) receivers have a signal containing all the pulses in sequence. If you don't yet have a receiver, the thread shows how you can attach a wire to get this signal from to easily available low cost receivers. If you already have a receiver, what is the model number?
If you don't want to hack the receiver, you could use a mega board. The 2009 board has only two external interrupts but the Mega has 6, so the mega could read 4 servo outputs on 4 pins using 4 external interrupts. Perhaps have a search to see if anyone has posted code to do this.
I don't know if it has an output with all the signals in sequence....
what can you mean whith "hack the receiver"?
If it need e reversible modification I'm very happy to do that...but if the hacking is definitive I'd prefer not to do...because I still use the receiver for models..
Hacking means soldering a wire to the receiver pcb. The Corona has a tiny PCB and would be difficult to solder. But for less than $12 shipped you can get a receiver that is quite easy to solder, see this thread: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1248474405/13#13
If you do get another receiver, make sure it is the correct frequency for you country.
mem I think I have found a receiver to be hacked..next week it will be in my hand!!
So I have some more question about your work...sorry if my questions are silly but I haven't still used Arduino.
To use your program I must use a specific pin on arduino 2009...it works reading input from any pin?
With your program I will read alla the signals..but if I use a n-channel TX and a k-channel RX in your program I must set the number of channel of the receiver or the transmitter?
With your program I can modify the input or I can only use it withouth modification?
Yes, it only works on pin 8 with an Arduino 168/328 (Arduino 2009). This is a hardware restriction and cannot be changed
yes, all channels (up to 8) will be available
must I set the number of channel of the receiver or the transmitter?
it should work with any number of channels up to and including 8
With your program I can modify the input or I can only use it >withouth modification?
It has worked without modification an all the receiver that I have tried
The last thing...for the moment....if I wnato to modify an input detected with your program...is it possible? for example if from the receiver I read a command that make a servo move to 100% can I modify it to move to 90%?
If you connect the servos to the Arduino instead of the receiver, the servos will be fully controlled by your sketch. But note that the decoder uses timer1 so you need to use the servoTimer2 library I linked in an earlier post.
