I just need a nudge in a general direction of study. No code to post yet. I need an Arduino to respond to a single button press. My experience is that my finger isn't faster than the loop so a loop counter will decrement 2 or 3 times when a digitalread(x)==LOW is used. What is best practice for ensuring that one button press = one loop of an if/then statement.
Take action when it becomes pressed.
Suggest you stick with looking at 'when a switch changes state' rather than its level.
Review this:
FYI
A flag to record the first detection then ignore subsequent detections until the button is released.
I usually post a link to my tutorial, but you said you wanted a nudge, so I won't.
and mind bouncing
This is what I use for a single button. I have a different version for multiple buttons in a list.
const byte ButtonPin = 2;
const unsigned long DebounceTime = 10;
boolean ButtonWasPressed = false;
unsigned long ButtonStateChangeTime = 0; // Debounce timer
pinMode (ButtonPin, INPUT_PULLUP); // Button between Pin and Ground
checkButton();
void checkButton()
unsigned long currentTime = millis();
boolean buttonIsPressed = digitalRead(ButtonPin) == LOW; // Active LOW
// Check for button state change and do debounce
if (buttonIsPressed != ButtonWasPressed &&
currentTime - ButtonStateChangeTime > DebounceTime)
// Button state has changed
ButtonWasPressed = buttonIsPressed;
ButtonStateChangeTime = currentTime;
if (ButtonWasPressed)
// Button was just pressed
// Button was just released
// Button is being held down
My tutorial on Debouncing Switches in Arduino may be helpful
