Arduino robot problem
Hey! I have made a multifunction Ardino-uno robot which includes voice control obstacle avoiding and blue tooth control it's a 4 wheeler robot
I have given connections according to schematic diagram and given power supply
When I upload the code only 2 out of 4 motors were running and now only 1 motor works
And ultrasonic sensor is not working, Bluetooth gets disconnected
I have tried using the functions one by one nothing works
I need to submit my project
This is schematic
Please take the time to read How to get the best out of this forum.
Then post a reply that includes your entire sketch (enclosed in code tags), a clear and legible schematic (pen and paper is fine), and links to documentation/datasheets for all the hardware you are using, Once you have done that, people will have the necessary information to perhaps be able to help you diagnose your problem(s). At the moment, you've given us nothing to work with.
And give a thought to what category you've posted in.
? where ?
Does the test code for just the 4 wheels work well?
Usually these kits ship with a 9vdc battery OR a 2xAA battery holder.
You will need TWO power supplies...
  1. One power supply for the Arduino and peripheral devices - 5vdc... so use 4xAA (1.5vdc x 4 = 6vdc)
  2. One power supply for the motors - probably 6vdc using 4xAA but maybe 5xAA (for 7.5vdc depending on motor driver board)
Or ONE power supply of about 6vdc with a BUCK converter...
  1. One power supply feeds a buck converter which feeds the Arduino and peripherals (5vdc)
  2. And... directly from the power supply, go straight to the motor driver board (6vdc)
This youtube channel builds the Elegoo robot car with bluetooth as you describe, in three videos. His kit only had one power supply, but they are LiPo, and probably 3.7vdc each for a total of 7.4vdc (see video 1 at 31:10).
I have given connections according to this schematic
When I upload the code in Arduino only two wheels were working and when I tried another code only one motor works now
And no moment in ultrasonic sensor
How can I make 4 motors work?
At first I tried with 3 (3.7v batteries)
Then immediately I got some sort of smoke from shield
And then I replaced the holder with 2 (3.7v) batteries everything was fine
But only 1 motor is running and no moment in ultrasonic
That is called a "signal" and I believe you need a new (thing that smoked).
If You post the code maybe somebody can tell. Without code and detailed schematics nobody can tell, only make wild guesses that waste time.
Nope once I replaced with 2 holder battery
It working without any problem I mean two motors and ultrasonic sensor were working perfectly
Now once I changed code only one motor was working
You. Need. To. Post. Your. Code.
As others have said, nobody can realistically help you if you don't do that.
Glad that fixed it... but the original was 2-holder. Hmm.
From what, to what?
#include <AFMotor.h>
#include <NewPing.h>
#include <Servo.h>
#define TRIG_PIN A0
#define ECHO_PIN A1
#define MAX_DISTANCE 200
#define MAX_SPEED 190
#define MAX_SPEED_OFFSET 20
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
AF_DCMotor motor1(1, MOTOR12_1KHZ);
AF_DCMotor motor2(2, MOTOR12_1KHZ);
AF_DCMotor motor3(3, MOTOR34_1KHZ);
AF_DCMotor motor4(4, MOTOR34_1KHZ);
Servo myservo;
boolean goesForward=false;
int distance = 100;
int speedSet = 0;
myservo.attach(10);
myservo.write(115);
delay(2000);
distance = readPing();
delay(100);
delay(100);
delay(100);
delay(100);
int distanceR = 0;
int distanceL = 0;
delay(40);
if(distance<=15)
moveStop();
delay(100);
moveBackward();
delay(300);
moveStop();
delay(200);
distanceR = lookRight();
delay(200);
distanceL = lookLeft();
delay(200);
if(distanceR>=distanceL)
turnRight();
moveStop();
}else
turnLeft();
moveStop();
}else
moveForward();
int lookRight()
myservo.write(50);
int distance = readPing();
delay(100);
myservo.write(115);
return distance;
int lookLeft()
myservo.write(170);
delay(100);
myservo.write(115);
return distance;
delay(100);
int readPing() {
delay(70);
int cm = sonar.ping_cm();
if(cm==0)
cm = 250;
return cm;
void moveStop() {
motor1.run(RELEASE);
motor2.run(RELEASE);
motor3.run(RELEASE);
motor4.run(RELEASE);
void moveForward() {
if(!goesForward)
goesForward=true;
motor1.run(FORWARD);
motor2.run(FORWARD);
motor3.run(FORWARD);
motor4.run(FORWARD);
for (speedSet = 0; speedSet < MAX_SPEED; speedSet +=2)
motor1.setSpeed(speedSet);
motor2.setSpeed(speedSet);
motor3.setSpeed(speedSet);
motor4.setSpeed(speedSet);
delay(5);
void moveBackward() {
goesForward=false;
motor1.run(BACKWARD);
motor2.run(BACKWARD);
motor3.run(BACKWARD);
motor4.run(BACKWARD);
delay(5);
void turnRight() {
void turnLeft() {
void voicecontrol()
if (Serial.available() > 0) {
value = Serial.read();
Serial.println(value);
if (value == '^') {
forward();
} else if (value == '-') {
backward();
} else if (value == '<') {
L = leftsee();
servo.write(spoint);
if (L >= 10 ) {
left();
Stop();
} else if (L < 10) {
Stop();
} else if (value == '>') {
R = rightsee();
if (R >= 10 ) {
right();
Stop();
} else if (R < 10) {
Stop();
} else if (value == '*') {
Stop();
I have tried this at first my two motors were running and next only one motor was running
I think your robot is "turning"... when the HC-SR04 sees an obstacle, the wheels are made to "turn" the robot.
Sensor not responding,wheels not Turning they are just on
See post #10.
To add code please click this link;
Tom.... :grinning: :+1: :coffee: :australia:
Bro now I have given for only Bluetooth control car ,the Bluetooth gets connected to mobile but the motors are not responding
#include <Servo.h>
#define TRIG_PIN A0
#define ECHO_PIN A1
Servo myservo;
int distance = 100;
int speedSet = 0;
  myservo.attach(10);
  myservo.write(115);
  delay(2000);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
 int distanceR = 0;
 int distanceL =  0;
 delay(40);
 if(distance<=15)
  moveStop();
  delay(100);
  moveBackward();
  delay(300);
  moveStop();
  delay(200);
  delay(200);
  delay(200);
    turnRight();
    moveStop();
  }else
    turnLeft();
    moveStop();
 }else
  moveForward();
int lookRight()
    myservo.write(50);
    delay(100);
    myservo.write(115);
    return distance;
int lookLeft()
    myservo.write(170);
    delay(100);
    myservo.write(115);
    return distance;
    delay(100);
int readPing() {
  delay(70);
  if(cm==0)
    cm = 250;
  return cm;
void moveStop() {
 if(!goesForward)
    goesForward=true;
    delay(5);
    goesForward=false;
    delay(5);
void turnRight() {
void turnLeft() {
void voicecontrol()
    if (value == '^') {
      forward();
      backward();
      L = leftsee();
      if (L >= 10 ) {
        left();
        Stop();
        Stop();
      R = rightsee();
      if (R >= 10 ) {
        right();
        Stop();
        Stop();
      Stop();
