hey,
i have bought a RTC ds1307 module and have set the date and time using the code below:
#include <DS3231.h>
// Init the DS3231 using the hardware interface
DS3231 rtc(SDA, SCL);
// Setup Serial connection
// Uncomment the next line if you are using an Arduino Leonardo
//while (!Serial) {}
// Initialize the rtc object
rtc.begin();
// The following lines can be uncommented to set the date and time
rtc.setDOW(WEDNESDAY); // Set Day-of-Week to SUNDAY
rtc.setTime(12, 0, 0); // Set the time to 12:00:00 (24hr format)
rtc.setDate(1, 1, 2014); // Set the date to January 1st, 2014
// Send Day-of-Week
Serial.print(rtc.getDOWStr());
Serial.print(" ");
// Send date
Serial.print(rtc.getDateStr());
Serial.print(" -- ");
// Send time
Serial.println(rtc.getTimeStr());
// Wait one second before repeating
delay (1000);
and i was not able to trigger the 5v relay, it would be helpful if i get the perfect code to trigger the relay in a specific time that has to be set
What is the criteria for activating the relay?
Is it a relay or a relay module? Schematics can be useful.
1. If you are using the following DS1307 RTC Module (Fig-1), then upload the sketch of Step-2 to operate the clock.
Figure-1:
2. Test Sketch
#include "RTClib.h"
byte prSec = 0;
RTC_DS1307 rtc; //RTC_DS3231 rtc; //user data type RTC_DS3231 variable rtc or object
DateTime nowDT;
//char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
void setup ()
rtc.begin();
rtc.adjust(DateTime(F(__DATE__), F(__TIME__))); //takes time and date from Computer
//rtc.adjust(DateTime(2021, 12, 31, 11, 59, 57));//set date-time manualy:yr,mo,dy,hr,mn,sec
void loop ()
showTime();
timeDelay();//1-sec interval of time display; this time delay comes form DS1307 itself
void showTime()
nowDT = rtc.now(); //nowDT hold Date and Time
byte myHour = nowDT.hour(); //myHour holds Hour of time of daya
Serial.print(myHour); //12:58:57 12:4:56
Serial.print(':');
byte myMin = nowDT.minute(); //to show leading zero of minute
if (myMin < 10)
Serial.print('0');
Serial.print(nowDT.minute()); Serial.print(':');
byte mySec = nowDT.second();
if (mySec < 10)
Serial.print('0');
Serial.println(mySec);//(nowDT.second(), DEC);
void timeDelay()
prSec = bcdSecond(); //current second of RTC
while (bcdSecond()== prSec)// != 1 )
prSec = bcdSecond(); //delay(1000);
byte bcdSecond()
nowDT = rtc.now();
if (nowDT.second() == 0 )
return 0;
return nowDT.second();
3. At what time of the day, do you want to trigger the relay? At what DPin your realy is connected?
I want the trigger to activated( on at 6.30 morning ,and off at 10.30night) relay pin to digital 4
Does sketch of Post-3 work? If so, set the time in 12- hrs format. Study data sheets or example programs to know how to set alarm ON/OFF times.
system
Closed
March 24, 2022, 6:28pm
6
