Arduino SCPI on Ethernet
Hi.
I'm trying to get my Arduino Opta to recive SCPI commands and reply back using ethernet.
I have gotten the Vrecker SCPI library to work using the serial connection, but I'm having a hard time sending reply back on the Ethernet connection.
Currently my code looks like this:
  Web Server
 A simple web server that shows the value of the analog input pins.
 using an Arduino Wiznet Ethernet shield.
 Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
 * Analog inputs attached to pins A0 through A5 (optional)
 created 18 Dec 2009
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
 modified 02 Sept 2015
 by Arturo Guadalupi
#include <SPI.h>
#include <Ethernet.h>
#include <Vrekrer_scpi_parser.h>
SCPI_Parser my_instrument;
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 100, 111);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
String sampledata;
  my_instrument.RegisterCommand(F("*IDN?"), &Identify);
  //my_instrument.SetCommandTreeBase(F("SYSTem:LED"));
    //my_instrument.RegisterCommand(F(":BRIGhtness"), &SetBrightness);
    //my_instrument.RegisterCommand(F(":BRIGhtness?"), &GetBrightness);
    //my_instrument.RegisterCommand(F(":BRIGhtness:INCrease"), &IncDecBrightness);
    //my_instrument.RegisterCommand(F(":BRIGhtness:DECrease"), &IncDecBrightness);
  // You can use Ethernet.init(pin) to configure the CS pin
  //Ethernet.init(10);  // Most Arduino shields
  //Ethernet.init(5);   // MKR ETH shield
  //Ethernet.init(0);   // Teensy 2.0
  //Ethernet.init(20);  // Teensy++ 2.0
  //Ethernet.init(15);  // ESP8266 with Adafruit Featherwing Ethernet
  //Ethernet.init(33);  // ESP32 with Adafruit Featherwing Ethernet
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("Ethernet WebServer Example");
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  // Check for Ethernet hardware present
  if (Ethernet.hardwareStatus() == EthernetNoHardware) {
    Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
    while (true) {
      delay(1); // do nothing, no point running without Ethernet hardware
  if (Ethernet.linkStatus() == LinkOFF) {
    Serial.println("Ethernet cable is not connected.");
  // start the server
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
//    my_instrument.ProcessInput(Serial, "\n");
  // listen for incoming clients
  if (client)
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected())
      if (client.available())
        char c = client.read();
        Serial.print(c);
        client.println("Vrekrer,SCPI Dimmer,#00," VREKRER_SCPI_VERSION);
        Serial.println("Vrekrer,SCPI Dimmer,#00," VREKRER_SCPI_VERSION);
        sampledata.concat(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n')
          // you're starting a new line
          Serial.println("Blank");
        else if (c != '\r')
          // you've gotten a character on the current line
          currentLineIsBlank = false;
          Serial.println("Not Blank");
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
void Identify(SCPI_C commands, SCPI_P parameters, Stream& interface) {
  interface.println(F("Vrekrer,SCPI Dimmer,#00," VREKRER_SCPI_VERSION));
  //*IDN? Suggested return string should be in the following format:
  // "<vendor>,<model>,<serial number>,<firmware>"
Sorry if this a newbee question and the solution is straight forward.
Hi
Put this in your loop
if (client) {
  my_instrument.ProcessInput(client, "\n");
EthernetClient behaves as a Stream so ProcessInput will handle it.
If you are using a VISA library for communication, you might want to create the EthernetServer at port 5025 (port used for SCPI)
EthernetServer server = EthernetServer(5025);
then your visa string or resource name should be TCPIP::your_ip::5025::SOCKET in your computer software
Here is a working example:
