Hello,
I'm using an Arduino Mega with an Ethernet shield on which the SD shield is included. I'm trying to copy an image to the SD (See code) but the transfer rate is too slow; it takes more than 30 seconds just to transfer 1KB ![]()
Here's the code. Please check it and let me know what I'm doing wrong. I've checked other SD examples that use Serial.print/Serial.write inside a for loop to copy byte by byte and did the same but to no avail. I'm guessing the problem is with the code but I'm not sure. Any help?
 SD card read/write
This example shows how to read and write data to and from an SD card file
The circuit:
* SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
created Nov 2010
by David A. Mellis
updated 2 Dec 2010
by Tom Igoe
This example code is in the public domain.
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
File myFile;
File myFile2;
byte storage[1500];
 Serial.print("Initializing SD card...");
 // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
 // Note that even if it's not used as the CS pin, the hardware SS pin
 // (10 on most Arduino boards, 53 on the Mega) must be left as an output
 // or the SD library functions will not work.
 pinMode(53, OUTPUT);
Â
 if (!SD.begin(4)) {
  Serial.println("initialization failed!");
  return;
 Serial.println("initialization done.");
Â
 // open the file. note that only one file can be open at a time,
 // so you have to close this one before opening another.
 myFile = SD.open("dog.jpg");
Â
 // if the file opened okay, write to it:
 if (myFile) {
  Serial.print("opening the img dog.jpg..");
 Â
  // close the file:
  Serial.println("done.");
  // if the file didn't open, print an error:
  Serial.println("error opening test.txt");
Â
 // re-open the file for reading:
 if (myFile) {
  // read from the file until there's nothing else in it:
  myFile2 = SD.open("dog2.jpg", FILE_WRITE);
  //Counter
  int i = 0;
  if(myFile2){
  while (myFile.available() && i < 1500) {
  storage[i] = myFile.read();
    i++;
    Serial.print("Copying to the memory..... ");
    Serial.println(i);
  }else{
   Serial.println("error opening Winter2.jpg");
  Serial.println("Done copying");
  int k = 0;
  while(k < i){
   myFile2.print(storage[k]);
   k++;
   Serial.print("Copying from the memory..... ");
   Serial.println(k);
  // close the file:
  myFile.close();
  myFile2.close();
  Serial.println("error opening winter.txt");
// nothing happens after setup
