Arduino seems to run both old and current program
Whenever I attempt to run this code:
#include <Wire.h>
#include <Adafruit_RGBLCDShield.h>
#include <utility/Adafruit_MCP23017.h>
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
unsigned long timStart =  0;
long timEnd = 0;
int pause = 500;
boolean flash = true;
byte flasherChar[] = {
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte upChar[] = {
  B00100,
  B01110,
  B11111,
  B00100,
  B00100,
  B00100,
  B00100,
  B00100
byte downChar[] = {
  B00100,
  B00100,
  B00100,
  B00100,
  B11111,
  B01110,
  B00100,
  B00000
  lcd.begin(2, 16);
  lcd.createChar(0, flasherChar);
  lcd.createChar(1, upChar);
  lcd.createChar(2, downChar);
  lcd.setCursor(0, 0);
  timStart = millis();
  int i;
  int charNo;
  String charList[] = {"u", "d"};
  Serial.println(i);
  if (lcd.readButtons() == 8 ) {
    Serial.println("u");
    charNo = 1;
  } else if (lcd.readButtons() == 4 ) {
    charNo = 2;
  if (timStart - timEnd >= pause) {
    if (charNo > -1) {
      lcd.write(charNo);
      charNo = -1;
    timEnd = timStart;
a left pointing arrow is continuously written on the lcd screen, one after the other, despite never having a left pointing arrow custom character defined in this program (I wouldn't expect it to do this with one of the defined characters either).
I believe this is because it somehow remembers the character from a previous sketch, though I cannot find that sketch anywhere. I realise there are flaws in the code but it does still run, I am just confused as to how a leftt pointing arrow ( a different style to the defined ones too) is being written to the screen.
Thanks this is my first forum post so apologies for any incorrect formatting or missing info.
OK, let's have a photo.
Paul__B:
I have now attached an image of what happens when I upload the program, wait a moment, press the up arrow once, wait a moment, then press the down arrow once.
Thank you and again sorry if this is not enough information.
Here's the image:
harrydotknee:
Wouldn't you? :roll_eyes:
That appears to be the "DEL" character, 0x7F, or the value -1 masked to 7 bits.
I see! Thank you so much, I was not aware of those characters, and the arrow looked the exact same as a character I had made before.
