Arduino Serial devices, how some code may conflict, etc.
Hello, I am working on a general use air quality setup which uses an SDS011 from Aliexpress.
It works well, seems very accurate, and is a nice little sensor..
However, all my programming experience is my little dabbling when I was in my mid teens, and now my actual job/business which is based in CNC.
I borrowed some code, but I don't understand it other than it uses the serial port for communication, and that it works nicely (also tried to use a different TX/RX on the Mega to no avail). I can take examples, combine them, and tweak them but my understanding of programming is limited.
In the end I find that the code interferes with otherwise working libraries such as the DT22, or say more complex ones such as Plot.ly over CC3000 wifi. The original code is here: http://www.instructables.com/id/Make-one-PM25-monitor-with-Arduino-UNO/
I've spent a while trying to get up to speed, and on some verions I removed all the display code whilst leraving the sensor code intact. But still issues with some devices.
I am not certain if RAM is a problem, or if it's just the fact that the code for the PM25/PM10 sensor wasn't written in a more contained manner.
Here is my somewhat obfuscated sketch, I tend to just run with things, have it work, and slowly add. It uses the sensor in question, a cheap OLED screen, and also limits how many times it addresses the screen since it appears the serial communication with the device is touchy. I don't program anything with complexity, this thing is bound to cause some annoyance since it's not organized, but it does work in it's current state.
const unsigned char dofly_DuanMa[10]={
  0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
//ä½�ç �
unsigned char const dofly_WeiMa[]={
  0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
long previousMillis = 0;
unsigned char displayTemp[8];
unsigned int Pm25 = 0;
unsigned int Pm10 = 0;
void DisPm25data(unsigned int value)
  int i;
  if(value/1000)
    displayTemp[0]=dofly_DuanMa[value/1000%10];//这里最å�Žæ˜¯åŠ å°�数点,共阳和共阴是相å��的。
    displayTemp[1]=dofly_DuanMa[value/100%10];
    displayTemp[2]=dofly_DuanMa[value/10%10];
    if((value/100) != 0)
    displayTemp[0]=dofly_DuanMa[value/100%10];//这里最å�Žæ˜¯åŠ å°�数点,共阳和共阴是相å��的。
    displayTemp[1]=dofly_DuanMa[value/10%10]|0x80;
    displayTemp[2]=dofly_DuanMa[value%10];
void DisPm10data(unsigned int value)
  int i;
  if(value/1000)
    displayTemp[4]=dofly_DuanMa[value/1000%10];//这里最å�Žæ˜¯åŠ å°�数点,共阳和共阴是相å��的。
    displayTemp[5]=dofly_DuanMa[value/100%10];
    displayTemp[6]=dofly_DuanMa[value/10%10];
    displayTemp[4]=dofly_DuanMa[value/100%10];//这里最å�Žæ˜¯åŠ å°�数点,共阳和共阴是相å��的。
    displayTemp[5]=dofly_DuanMa[value/10%10]|0x80;
    displayTemp[6]=dofly_DuanMa[value%10];
void ProcessSerialData()
  uint8_t mData = 0;
  uint8_t i = 0;
  uint8_t mPkt[10] = {0};
  uint8_t mCheck = 0;
    // from www.inovafitness.com
    // packet format: AA C0 PM25_Low PM25_High PM10_Low PM10_High 0 0 CRC AB
     mData = Serial.read();     delay(2);//wait until packet is received
    if(mData == 0xAA)//head1 ok
        mPkt[0] =  mData;
        if(mData == 0xc0)//head2 ok
          mPkt[1] =  mData;
          mCheck = 0;
          for(i=0;i < 6;i++)//data recv and crc calc
             mPkt[i+2] = Serial.read();
             delay(2);
             mCheck += mPkt[i+2];
          mPkt[8] = Serial.read();
          delay(1);
	  mPkt[9] = Serial.read();
          if(mCheck == mPkt[8])//crc ok
            Serial.flush();
            //Serial.write(mPkt,10);
            Pm25 = (uint16_t)mPkt[2] | (uint16_t)(mPkt[3]<<8);
            Pm10 = (uint16_t)mPkt[4] | (uint16_t)(mPkt[5]<<8);
            if(Pm25 > 9999)
             Pm25 = 9999;
            if(Pm10 > 9999)
             Pm10 = 9999;
            //get one good packet
             return;
//my code///////////////////////////////////////////////////////
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
////////////////////////LCD Refresh Timer
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis1 = 0;        // will store last time LED was updated
// constants won't change :
const long interval = 5000;           // interval at which to blink (milliseconds)
    Serial.begin(9600,SERIAL_8N1);
    Pm25=0;
    Pm10=0;
// by default, we'll generate the high voltage from the 3.3v line internally! (neat!)
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3C (for the 128x64)
  // init done
// 主循环
  ProcessSerialData();
  if(currentMillis - previousMillis1 >= interval) {
   display.clearDisplay();
  // text display tests
  display.setTextSize(2);
  display.setTextColor(WHITE);
  display.setCursor(0,0);
  display.print("Pm2.5:");
  display.setCursor(75,0);
  display.print(Pm25);
  display.setCursor(0,15);
  display.print("Pm10 :");
  display.setCursor(75,15);
  display.print(Pm10);
  display.display();
In the end I'd like your opinion on the code written for the sensor, if it's causing a conflict, and so forth. If I were to just avoid problems and not care.. I guess IC2 for a temp/humidity sensor, then some sort of offloading of the Plot.ly VIA serial to another arduino would work. But I suspect it'll all work on one.
My end product or dream is a unit which sends the data to Plot.ly, also averages out the sensor readings (PM2.5,PM10, Temp, Humidity, and etc), and finally perhaps does a running line/Scope like plot over various intervals. The volcano is bad here in Hawai'i, and so it would be nice to have a practical device that I can mill up a nice wood case for if I manage to finish this simple project.
The way you are reading in the data from serial shouldn't work.
     mData = Serial.read();     delay(2);//No, serial doesn't work like this.
        mPkt[0] =  mData;
          mPkt[1] =  mData;
          mCheck = 0;
             mPkt[i+2] = Serial.read(); //this may not return anything!
             delay(2);
          delay(1);
serial.read() gets a character from the serial buffer if one is there. If there isn't one there, it returns -1.
You need to use Serial.Available() to check if there are bytes to copy out, before trying to read them with Serial.Read() - and you should try to assemble the message through multiple passes of Loop, which means you'll want to have a global variable saving the index of the last byte in mPkt that you wrote to (and mPkt needs to be either global or static - the latter is probably better practice here)
Take a look at how other people handle that - there tons of code around that handles commands over serial that you can use as a basis.
You could probably use one of the examples in serial input basics in place of your processSerialData() function. There is also a parse example.
...R
Thanks for the replies. Unfortunately, the original serial code wasn't mine, and I'm behind in that area. I work with GCode which is very easy, and so I'm a newbie even though I'm acquainted with most of this...
I'm not certain if I'll be able to fix it. I enjoy doing this, but it's partially for a practical purpose, and I'm nearing the end of my rope for now since I'm hitting that tipping point of how much time I've spent. I suspect once this is ironed out the rest should be easy, as I got Plot.ly working, and everything else on it's own accord.
Is there anybody around here that would be willing to fix this up for a reasonable fee?
I know that sounds very poor of a sport but I'd like to have fun with this, and cheat with easy to use libraries whilst leaving this stuff until later if this hobby/practical use progresses.
For now though, the code does in fact work even though it's written in an obfuscated way.
It's very interesting to see how the volcanic pollution travels, and how the view of the ocean's horizon changes with the particulate readings.
