Arduino sketch for NodeMCU v1.0 (ESP8266-12E) have no error of compiling but not
i compiled a Arduino Sketch for NodeMCU v1.0 (ESP8266-12E) which have no error while i test with verifiy button in Arduino IDE 1.8.6 but i don't know what is the problem when i upload and test it . it [ NodeMCU v1.0 (ESP8266-12E) ] is not showing an static IP address while there is turned ON WiFi hotspot from my android phone. I'm sharing two codes (code 1, code 2) here. Code 2 connect to the WiFi Hotspot but i make changes in code 2 to make code 1 for desired output which is not working. Need help for making proper code.
For better understanding , what i want you can check this uploaded video on Youtube.
Home automation circuit using NodeMCU v1.0 (ESP8266-12E). - YouTube or
by typing in search bar in youtube.com
code 1
code 1
#include
int pin1 = 2; // GPIO 14 (D5)
int pin2 = 3; // GPIO 5 (D1)
int pin3 = 6; // GPIO 5 (D2)
const char* ssid = "wifi";
const char* password = "12345678";
WiFiServer server(80);
delay(10);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(6, OUTPUT);
// Connect to WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Start the server
server.begin();
Serial.println("Server started");
// Print the IP address
Serial.print("Use this URL to connect: ");
Serial.print("http://");
Serial.print(WiFi.localIP());
Serial.println("/");
// Check if a client has connected
WiFiClient client = server.available();
if (!client) {
return;
// Wait until the client sends some data
Serial.println("new client");
while(!client.available()){
delay(1);
// Read the first line of the request
String request = client.readStringUntil('\r');
Serial.println(request);
client.flush();
// Match the request
int value = LOW;
if (request.indexOf("/pin1=ON") != -1) {
digitalWrite(2, HIGH);
value = HIGH;
if (request.indexOf("/pin1=OFF") != -1) {
digitalWrite(2, LOW);
value = LOW;
if (request.indexOf("/pin2=ON") != -1) {
digitalWrite(3, HIGH);
value = HIGH;
if (request.indexOf("/pin2=OFF") != -1) {
digitalWrite(3, LOW);
value = LOW;
if (request.indexOf("/pin3=ON") != -1) {
digitalWrite(6, HIGH);
value = HIGH;
if (request.indexOf("/pin3=OFF") != -1) {
digitalWrite(6, LOW);
value = LOW;
// Set ledPin according to the request
//digitalWrite(ledPin, value);
// Return the response
client.println("Content-Type: text/html");
client.println(""); // do not forget this one
client.println("");
client.println("");
client.println("");
client.println("");
client.println("");
client.println("");
client.println("<body bgcolor = "#f7e6ec">");
client.println("
client.println("
Wifi Based Project
client.println("");
client.println("
client.println("");
client.println("<a href="/a"">Data
client.println("");
client.println("
client.println("");
client.println("Load 1");
client.println("<a href="/l1on"">Turn On ");
client.println("<a href="/l1off"">Turn Off
client.println("");
client.println("
client.println("");
client.println("Load 2");
client.println("<a href="/l2on"">Turn On ");
client.println("<a href="/l2off"">Turn Off
client.println("");
client.println("
client.println("");
client.println("Load 3");
client.println("<a href="/l3on"">Turn On ");
client.println("<a href="/l3off"">Turn Off
client.println("");
client.println("
client.println("");
client.println("
client.println("");
client.println("<table border="5">");
client.println("
client.println("");
if(digitalRead(pin1)){client.print("Load 1 is ON");}
else{client.print("Load 1 is OFF");}
if(digitalRead(pin2)){client.print("Load 2 is ON");}
else{client.print("Load 2 is OFF");}
if(digitalRead(pin3)){client.print("Load 3 is ON");}
else{client.print("Load 3 is OFF");}
client.println("");
client.println("");
client.println("");
client.println("");
delay(1);
Serial.println("Client disonnected");
Serial.println("");
[enter image description here][1]
// if you will upload this code in your NodeMCU v1.0 (ESP8266-12E) , this will
connect with your Android phone. You can consider it, code 2 and above code 1. i'm also sharing code 2 in other post with same title
Also posted at:
If you're going to do that then please be considerate enough to add links to the other places you cross posted. This will let us avoid wasting time due to duplicate effort and also help others who have the same questions and find your post to discover all the relevant information. When you post links please always use the chain links icon on the toolbar to make them clickable.
answer/ solution is on Arduino StackExchange. and it was already there when you asked here.
Now they've even signed up for GitHub just so they can post the same thing there:
Talk about a cross posting spree! And that's just the sites I monitor. I would be surprised if they haven't posted a couple other places too.
