ESPAlexa works on NodeMCU but does not compile on ESP32
Hello Guru’s experts, I had been using ESPAlexa with NodeMCU and my program worked perfectly fine, however now that I want to shift to ESP32 (30pin) but the program is giving error on compilation. Can someone please help me guide me to fix the issue.
In file included from C:\SMD\ShukDa\Documents\Arduino\VagdaMadhuraSwitch\VagdaMadhuraSwitch.ino:49:
c:\SMD\ShukDa\Documents\Arduino\libraries\Espalexa\src/Espalexa.h: In member function 'void Espalexa::encodeLightId(uint8_t, char*)':
c:\SMD\ShukDa\Documents\Arduino\libraries\Espalexa\src/Espalexa.h:123:5: error: 'WiFi' was not declared in this scope
123 |     WiFi.macAddress(mac);
c:\SMD\ShukDa\Documents\Arduino\libraries\Espalexa\src/Espalexa.h: In member function 'void Espalexa::serveDescription()':
c:\SMD\ShukDa\Documents\Arduino\libraries\Espalexa\src/Espalexa.h:214:25: error: 'WiFi' was not declared in this scope
214 |     IPAddress localIP = WiFi.localIP();
c:\SMD\ShukDa\Documents\Arduino\libraries\Espalexa\src/Espalexa.h: In member function 'void Espalexa::respondToSearch()':
c:\SMD\ShukDa\Documents\Arduino\libraries\Espalexa\src/Espalexa.h:288:25: error: 'WiFi' was not declared in this scope
288 |     IPAddress localIP = WiFi.localIP();
c:\SMD\ShukDa\Documents\Arduino\libraries\Espalexa\src/Espalexa.h: In member function 'bool Espalexa::begin(AsyncWebServer*)':
c:\SMD\ShukDa\Documents\Arduino\libraries\Espalexa\src/Espalexa.h:328:18: error: 'WiFi' was not declared in this scope
328 |     escapedMac = WiFi.macAddress();
Multiple libraries were found for "ArduinoJson.h"
Used: C:\SMD\ShukDa\Documents\Arduino\libraries\ArduinoJson
Not used: C:\SMD\ShukDa\Documents\Arduino\libraries\ThingsIoT
Not used: C:\SMD\ShukDa\Documents\Arduino\libraries\ThingESP
Multiple libraries were found for "WiFiUdp.h"
Used: C:\Users\ShukDa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.4\libraries\WiFi
Not used: C:\SMD\ShukDa\Documents\Arduino\libraries\WiFiEspAT
Not used: C:\SMD\ShukDa\Documents\Arduino\libraries\WiFi101_Generic
Not used: C:\SMD\ShukDa\Documents\Arduino\libraries\arduino_176609
Not used: C:\SMD\ShukDa\Documents\Arduino\libraries\WiFiNINA
exit status 1
Compilation error: exit status 1
Someone Please help.
Start by posting your full sketch
Exactly which ESP32 variant are you using ?
#include <LiquidCrystal.h>
#include <EEPROM.h>
#include <ESPAsyncWebServer.h>
#include <ArduinoJson.h>
#define ESPALEXA_ASYNC //it is important to define this before #include <Espalexa.h>!
#ifdef ARDUINO_ARCH_ESP32
#include <WiFi.h>
#include <AsyncTCP.h>
#else
#include <ESP8266WiFi.h>
#include <ESPAsyncTCP.h>
#endif
// define the GPIO connected with Relays based on processor architecure
#define AlexaRelay01 19
#define AlexaRelay02 18
#define AlexaRelay03 5
#define AlexaRelay04 17
#define WiFiStatus 2
#else
#define AlexaRelay01 4  //D2
#define AlexaRelay02 0  //D3
#define AlexaRelay03 2  //D4
#define AlexaRelay04 14 //D5
#define WiFiStatus D0
#endif
//callback functions
void firstSwitchChanged(EspalexaDevice* dev);
void secondSwitchChanged(EspalexaDevice* dev);
void thirdSwitchChanged(EspalexaDevice* dev);
void fourthSwitchChanged(EspalexaDevice* dev);
// WiFi Credentials
const char* ssid = "XXXXXXXXX";
const char* password = "XXXXXXXXXX";
int WifiLEDBlink = 0;
const char* PARAM_MESSAGE = "message";
boolean SendResponse = false ;
// device names
String Device_1_Name = "S1";
String Device_2_Name = "S2";
String Device_3_Name = "S3";
String Device_4_Name = "S4";
boolean wifiConnected = false;
// These are for storing relaystates and not relaypin numbers, relay pin numbers are stored in AlexaRelay variables
int Relay01 = 1;
int Relay02 = 1;
int Relay03 = 1;
int Relay04 = 1;
Espalexa espalexa;
AsyncWebServer server(80);
// Set your Static IP address
IPAddress local_IP(192, 168, 150, 112);
// Set your Gateway IP address
IPAddress gateway(192, 168, 150, 1);
IPAddress subnet(255, 255, 255, 0);
IPAddress primaryDNS(8, 8, 8, 8); // optional
IPAddress secondaryDNS(208, 67, 222, 222); // optional
  delay(10);
  EEPROM.begin(512);
  //Prepare and Initialize GPIO4,0,2,14 PINS D2,D3,D4,D5 NodeMcu
  pinMode(AlexaRelay01, OUTPUT);
  digitalWrite(AlexaRelay01, EEPROM.read(256));
  pinMode(AlexaRelay02, OUTPUT);
  digitalWrite(AlexaRelay02, EEPROM.read(257));
  pinMode(AlexaRelay03, OUTPUT);
  digitalWrite(AlexaRelay03, EEPROM.read(258));
  pinMode(AlexaRelay04, OUTPUT);
  digitalWrite(AlexaRelay04, EEPROM.read(259));
  //WiFi Status Blue Onboard LED
  pinMode(WiFiStatus, OUTPUT);
  //Initialize RelayStates with last power state stored in EEPROM
  Relay01 = EEPROM.read(256);
  Relay02 = EEPROM.read(257);
  Relay03 = EEPROM.read(258);
  Relay04 = EEPROM.read(259);
  setOnOffRelay();
  // Configures static IP address
  if (!WiFi.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS)) {
    Serial.println("WARNING....STA Failed to configure static ip 192.168.150.112..");
   WiFi.setSleep(false); //.setSleepMode(WIFI_NONE_SLEEP);
  // Connect to WiFi network
  Serial.print("Conecting to  ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    if ( WifiLEDBlink == 1 ) {
      digitalWrite(WiFiStatus, HIGH);// Turn Off OnBoard Blue LED
      WifiLEDBlink = 0; //Toggle switch for led blink
    } else if ( WifiLEDBlink == 0 ) {
      digitalWrite(WiFiStatus, LOW);// Turn Off OnBoard Blue LED
      WifiLEDBlink = 1; //Toggle switch for led blink
    Serial.print(".");
  digitalWrite(WiFiStatus, LOW);// Turn On OnBoard Blue LED
  Serial.print("Connected to ");
  Serial.print("IP address is : ");
  if (WiFi.status() == WL_CONNECTED)
    server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
      //request->send(200, "text/plain", "Shuk ba this is where you will return the relay states");
      // Read the first line of the request
      String req = request->url().c_str();
      // Prepare the json response
      AsyncResponseStream *response = request->beginResponseStream("application/json");
      DynamicJsonDocument json(1024);
      json["REL01"] = "" + String(Relay01) + "";
      json["REL02"] = "" + String(Relay02) + "";
      json["REL03"] = "" + String(Relay03) + "";
      json["REL04"] = "" + String(Relay04) + "";
      json["IP"] = WiFi.localIP().toString();
      serializeJson(json, *response);
      request->send(response);
    server.on("/test", HTTP_GET, [](AsyncWebServerRequest *request){
      request->send(200, "text/plain", "This is an answer for test call you made, System is Up and Running fine..");
    // Send a GET request to <IP>/get?message=<message>
    server.on("/get", HTTP_GET, [] (AsyncWebServerRequest *request) {
        String message;
        if (request->hasParam(PARAM_MESSAGE)) {
            message = request->getParam(PARAM_MESSAGE)->value();
            message = "No message sent";
        request->send(200, "text/plain", "Hello, GET: " + message);
    server.onNotFound([](AsyncWebServerRequest *request){
      if (!espalexa.handleAlexaApiCall(request)) //if you don't know the URI, ask espalexa whether it is an Alexa control request
          if (req.indexOf("Relay01=1") != -1) {
            Relay01 = 1;
            SendResponse = true ;
          } else if (req.indexOf("Relay01=0") != -1) {
            Relay01 = 0;
          } else if (req.indexOf("Relay02=1") != -1) {
            Relay02 = 1;
          } else if (req.indexOf("Relay02=0") != -1) {
            Relay02 = 0;
          } else if (req.indexOf("Relay03=1") != -1) {
            Relay03 = 1;
            //espalexa.getDevice(2)->setValue(0);
          } else if (req.indexOf("Relay03=0") != -1) {
            Relay03 = 0;
            //espalexa.getDevice(2)->setValue(255);
          } else if (req.indexOf("Relay04=1") != -1) {
            Relay04 = 1;
            //espalexa.getDevice(3)->setValue(0);
          } else if (req.indexOf("Relay04=0") != -1) {
            Relay04 = 0;
            //espalexa.getDevice(3)->setValue(255);
          } else if (req.indexOf("Reboot") != -1) {
            //March 03, 2022 added code snippet to restart the module
            ESP.restart();
          //whatever you want to do with 404s
          request->send(404, "text/plain", "Not found");
          setOnOffRelay();
          if (SendResponse)
            SendResponse = false;
    // Define your devices here.
    espalexa.addDevice(Device_1_Name, firstSwitchChanged, EspalexaDeviceType::onoff); //simplest definition, default state off
    espalexa.addDevice(Device_2_Name, secondSwitchChanged, EspalexaDeviceType::onoff);
    espalexa.addDevice(Device_3_Name, thirdSwitchChanged, EspalexaDeviceType::onoff);
    espalexa.addDevice(Device_4_Name, fourthSwitchChanged, EspalexaDeviceType::onoff);
    //give espalexa a pointer to your server object so it can use your server instead of creating its own
    espalexa.begin(&server);
    Serial.println("System is Now Alexa Enabled");
//    Serial.println("01 = " + String(EEPROM.read(256)));
//    Serial.println("02 = " + String(EEPROM.read(257)));
//    Serial.println("03 = " + String(EEPROM.read(258)));
//    Serial.println("04 = " + String(EEPROM.read(259)));
  espalexa.loop();
  delay(1);
//our callback functions
void firstSwitchChanged(EspalexaDevice* d)
  if (d == nullptr) return; //this is good practice, but not required
  //Control the device
  if (d->getValue())
    digitalWrite(AlexaRelay01, HIGH);
    EEPROM.write(256, HIGH);
    EEPROM.commit();
    Relay01 = HIGH;
    Serial.println("Device1 ON");
    digitalWrite(AlexaRelay01, LOW);
    EEPROM.write(256, LOW);
    EEPROM.commit();
    Relay01 = LOW;
    Serial.println("Device1 OFF");
void secondSwitchChanged(EspalexaDevice* d)
  if (d->getValue())
      digitalWrite(AlexaRelay02, HIGH);
      EEPROM.write(257, HIGH);
      EEPROM.commit();
      Relay02 = HIGH;
      Serial.println("Device2 ON");
    digitalWrite(AlexaRelay02, LOW);
    EEPROM.write(257, LOW);
    EEPROM.commit();
    Relay02 = LOW;
    Serial.println("Device2 OFF");
void thirdSwitchChanged(EspalexaDevice* d)
  if (d->getValue())
      digitalWrite(AlexaRelay03, HIGH);
      EEPROM.write(258, HIGH);
      EEPROM.commit();
      Relay03 = HIGH;
      Serial.println("Device3 ON");
    digitalWrite(AlexaRelay03, LOW);
    EEPROM.write(258, LOW);
    EEPROM.commit();
    Relay03 = LOW;
    Serial.println("Device3 OFF");
void fourthSwitchChanged(EspalexaDevice* d)
  if (d->getValue())
      digitalWrite(AlexaRelay04, HIGH);
      EEPROM.write(259, HIGH);
      EEPROM.commit();
      Relay04 = HIGH;
      Serial.println("Device4 ON");
    digitalWrite(AlexaRelay04, LOW);
    EEPROM.commit();
    Relay04 = LOW;
    Serial.println("Device4 OFF");
void setOnOffRelay() {    // Set GPIO according to the request
  // Store state in EEPROM & then Set GPIO4 (D2) according to the request
  EEPROM.write(256, Relay01);
  digitalWrite(AlexaRelay01, Relay01);
  // Store state in EEPROM & then Set GPIO0 (D3) according to the request
  EEPROM.write(257, Relay02);
  digitalWrite(AlexaRelay02, Relay02);
  // Store state in EEPROM & then Set GPIO2 (D4) according to the request
  EEPROM.write(258, Relay03);
  digitalWrite(AlexaRelay03, Relay03);
  // Store state in EEPROM & then Set GPIO14 (D5) according to the request
  EEPROM.write(259, Relay04);
  digitalWrite(AlexaRelay04, Relay04);
  // Committ stored state from flash to EEPROM for power cycle initialization
  EEPROM.commit();
//  Serial.println(String(EEPROM.read(256)));
//  Serial.println(String(EEPROM.read(257)));
//  Serial.println(String(EEPROM.read(258)));
//  Serial.println(String(EEPROM.read(259)));
I am using 30pin ESP32 variant (DOIT ESP32 DEVKIT V1), actual picture is as below:
Please help.
WiFi does not appear to be declared in the sketch. Does exactly the same sketch compile for the NodeMCU ?
Move this line to the end of the library list.
For NodeMCU = Yes it has been working perfectly fine for last 3 years. Just switching to ESP32 and can’t figureout the issue.
In file included from C:\SMD\ShukDa\Documents\Arduino\VagdaMadhuraSwitch\VagdaMadhuraSwitch.ino:48:
exit status 1
Getting above after doing the change as directed.
Move #include <Espalexa.h> as a last one of the list
I see you use ESP32 Wroom DA , What board is selected in the IDE.
If it is not this one , below ,then ESP8266WiFi.h will be used and WiFi.h skipped.
 ARDUINO_ARCH_ESP32
Try this.
//#ifdef ARDUINO_ARCH_ESP32
#include <WiFi.h>
//#else
//#include <ESP8266WiFi.h>
//#include <ESPAsyncTCP.h>
//#endif
Try like this
#include <EEPROM.h>
#include <WiFi.h>
That should also work but get rid of the #ifdef ARDUINO_ARCH_ESP32.
Does the code compile?
i just saw that this board is actually a pre prosessor macro that define a wide range of ESP32 boards.
So this is not the problem.
ARDUINO_ARCH_ESP32
Just moving this single line to the end of definations worked like a charm. Thanks much everyone and special one to Kmin.
