Arduino -> SRF02 (Fake-Mode Problems)
Hi everyone,
I have been trying to measure the distance between two SRF02 sensors (in Fake Mode).
I have connected two SRF02 sensors on my Arduino by I2C Bus system.
The idea is that one SRF02 should send a signal and the second SRF02 should be waiting for the signal.
The problem is that I get wrong distances as result.
Here is my Code…
#include <Wire.h>
#define srfAddress1 0x70 // Address of the SRF02
#define srfAddress2 0x72 // Address of the SRF02
#define cmdByte 0x00 // Command byte
#define rangeByte 0x02 // Byte for start of ranging data
byte highByte = 0x00; // Stores high byte from ranging
byte lowByte = 0x00; // Stored low byte from ranging
int range = 0;
int rangeData;
Wire.begin();
rangeData=getRange();
int getRange()
//Sensor 1 –Sender-
Wire.beginTransmission(srfAddress1); // Start communticating with SRF02
Wire.write((uint8_t)cmdByte); // Send Command Byte
Wire.write((uint8_t)0x5C); // Transmit an 8 cycle 40khz burst - no ranging takes place
Wire.endTransmission();
//Sensor 2 –Empfänger-
Wire.beginTransmission(srfAddress2); // Start communticating with SRF02
Wire.write((uint8_t)0x57); // Fake Ranging Mode - Result in centimeters
delay(100);
Wire.beginTransmission(srfAddress2); // start communicating with SRFmodule
Wire.write((uint8_t)rangeByte); // Call the register for start of ranging data
Wire.requestFrom(srfAddress2, 2); // Request 2 bytes from SRF module
while(Wire.available() < 2); // Wait for data to arrive
highByte = Wire.read(); // Get high byte
lowByte = Wire.read(); // Get low byte
range = (highByte << 8 ) + lowByte; // Put them together
//print it
Serial.print("Entfernung zwischen 1&2: ");
Serial.println(range, DEC);
delay(1500);
return(range); // Returns Range
First: use code tags for your code parts, else the tag parsing on the server may omit some code.
May I guess: your result is about 10-15cm wrong?
The transmission of the range command takes approximately 300us which translates to about 10cm. If there's another delay in the communication that I've missed it may be more. The datasheet explicitly states that you are responsible for the synchronization of the two sensors if used this way.
"use code tags for your code parts, else the tag parsing on the server may omit some code."
-> Ok next time i will use it.
"May I guess: your result is about 10-15cm wrong?
The transmission of the range command takes approximately 300us which translates to about 10cm. If there's another delay in the communication that I've missed it may be more. The datasheet explicitly states that you are responsible for the synchronization of the two sensors if used this way."
-> Ok thanks. I will check if the result is constant wrong. (for example every time about 10cm) Then i will reduce every time the result about 10cm. So i guess i get the right result.
I tested it and the problem is that the result is not constant wrong.
for example: the right length is 37cm -> result of srf02: 27cm
27cm -> result of srf02: 25cm
I changed a bit the code. I call “Sensor2” (receive the signal) before “Sensor1” (transmit the signal).
If i call Sensor2 after Sensor1 it could be that the Signal is just gone. That was my intention.
#include <Wire.h>
int range = 0;
int rangeData;
   Wire.begin();
int getRange()                                                      // This function gets a ranging from the SRF02
//Sensor 1 –Sender-
  delay(100);                                                           // Wait for ranging to be complete
  //print it
  delay(1500);
What’s the result of that change? Did you get better (more constant) readings?
