Hi guys, I have an Arduino Uno and stepper motor. i want to be able to step the motor clockwise until it hits the limit switch then steps anticlockwise for specific steps. i had wrote a code that you can see below but it doesn't work. if you guys help me i would be Grateful.
These statements compare Stepping with false then true with a half second delay between the comparisons and throws away the answers. I don't think that is what you meant to do or if you did I don't see why.
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
We need to see how you have connected the stepper and the switch, also how you are powering the arduino and the stepper.
Also a link to the specs on your stepper motor.
no i just want, after it reaches the limit switch stop and then after half second ,start in reverse direction for specific steps . how can i correct the code?
