Hi, my arduino (genuino since im in sweden) won't compile neither verify, i do not get any error messages and i have tried other versions like 1.6.5 but i had no success in that. are there any solution i can try?
- Restart the IDE
- Check the box at File > Preferences > Show verbose output during: compilation
- compile
- After it gets stuck select all the text in the black window at the bottom of the IDE and paste it here using the code tags(</> button). If it's too long then save it in a text file and attach it.
pert:
- Restart the IDE
- compile
here is the messages i get.
Arduino Compile..txt (6.35 KB)
He said to use code tags - copy/paste it into your post, and put it inside the code tags.
That way we don't have to download it to view it - these forums are dumb, and don't let you view attachments without saving them to your computer (and often aren't usable at all if you're using a phone)
For the benefit of others, here is the compiler output.... it's just... stopping?
C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files\Arduino\hardware" -tools "C:\Program Files\Arduino\tools-builder" -tools "C:\Program Files\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files\Arduino\libraries" -libraries "C:\Users\Sebastian Persson\Documents\Arduino\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10606 -build-path "C:\Users\SEBAST~1\AppData\Local\Temp\builda5ef980fe5b9662f4c403d048f3116f1.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Program Files\Arduino\examples\01.Basics\AnalogReadSerial\AnalogReadSerial.ino"
C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files\Arduino\hardware" -tools "C:\Program Files\Arduino\tools-builder" -tools "C:\Program Files\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files\Arduino\libraries" -libraries "C:\Users\Sebastian Persson\Documents\Arduino\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10606 -build-path "C:\Users\SEBAST~1\AppData\Local\Temp\builda5ef980fe5b9662f4c403d048f3116f1.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Program Files\Arduino\examples\01.Basics\AnalogReadSerial\AnalogReadSerial.ino"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -M -MG -MP -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10606 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\SEBAST~1\AppData\Local\Temp\builda5ef980fe5b9662f4c403d048f3116f1.tmp\sketch\AnalogReadSerial.ino.cpp"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10606 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\SEBAST~1\AppData\Local\Temp\builda5ef980fe5b9662f4c403d048f3116f1.tmp\sketch\AnalogReadSerial.ino.cpp"
"C:\Program Files\Arduino\tools-builder\ctags\5.8-arduino2/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns "C:\Users\SEBAST~1\AppData\Local\Temp\builda5ef980fe5b9662f4c403d048f3116f1.tmp\preproc\ctags_target.cpp"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10606 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\SEBAST~1\AppData\Local\Temp\builda5ef980fe5b9662f4c403d048f3116f1.tmp\sketch\AnalogReadSerial.ino.cpp" -o "C:\Users\SEBAST~1\AppData\Local\Temp\builda5ef980fe5b9662f4c403d048f3116f1.tmp\sketch\AnalogReadSerial.ino.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -x assembler-with-cpp -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10606 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\wiring_pulse.S" -o "C:\Users\SEBAST~1\AppData\Local\Temp\builda5ef980fe5b9662f4c403d048f3116f1.tmp\core\wiring_pulse.S.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10606 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\WInterrupts.c" -o "C:\Users\SEBAST~1\AppData\Local\Temp\builda5ef980fe5b9662f4c403d048f3116f1.tmp\core\WInterrupts.c.o"
sorry about that, new to this forum and we only use this program to learn programming at school but i do a little bit at home aswell.
thanks for putting the code in for me and yes and no depending on what you mean sometimes it completes and i dont get any error messages just the orange warning color but no message and sometimes it get stuck at 75% at just stay there for hours.
famezxl:
Leave the verbose output on and next time that happens post the output here. Maybe it will provide some clue to the cause.
