Hello everyone! I was working with an SMD reflow soldering station with a touchscreen shield and Arduino and encountered an issue with the touchscreen. The text and graphics display are fine, but the issue is that the X-axis of the touch control is flipped. Please have a look at the Code here.
#include <TouchScreen.h>
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
#include <max6675.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include "icon.h"
// Pinouts
#define fan 1
#define relay 0
#define buzzer 11
#define thermoCS 10
#define thermoDO 12
#define thermoCLK 13
#define oneWireBus A5
// Variables
int temp = 0;
int temp1 = 0;
unsigned int preHeat = 120;
unsigned int reflow = 180;
unsigned int coolDown = 50;
unsigned int timer = 60;
unsigned int mm = 88;
unsigned int ss = 88;
bool reflowing;
bool cooling;
bool fanState;
int saveTimer;
unsigned long previousMillis = 0;
int x = 165, y = 231, w = 36, h = 36;
MCUFRIEND_kbv tft;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
OneWire oneWire(oneWireBus);
DallasTemperature sensors(&oneWire);
// require touch screen calibration
// Put your calibrated touchSensor values here
int XP = 8, XM = A2, YP = A3, YM = 9; //240x320 ID=0x3229
//int XP = 9, XM = A3, YP = A2, YM = 8; //240x320 ID=0x3229
const int TS_LEFT = 139, TS_RT = 895, TS_TOP = 901, TS_BOT = 118;
#define MINPRESSURE 200
#define MAXPRESSURE 1000
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
// buttons
Adafruit_GFX_Button on_btn, off_btn, up1, dwn1, up2, dwn2, up3, dwn3, up4, dwn4, fanBtn;
// get touch input
int pixel_x, pixel_y;
bool Touch_getXY(void)
TSPoint p = ts.getPoint();
pinMode(YP, OUTPUT); //restore shared pins
pinMode(XM, OUTPUT);
digitalWrite(YP, HIGH); //because TFT control pins
digitalWrite(XM, HIGH);
bool pressed = (p.z > MINPRESSURE && p.z < MAXPRESSURE);
if (pressed) {
pixel_x = map(p.x, TS_LEFT, TS_RT, 0, tft.width());
pixel_y = map(p.y, TS_TOP, TS_BOT, 0, tft.height());
return pressed;
#define BLACK 0x0000
#define WHITE 0xFFFF
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
void setup(void)
//Serial.begin(9600); // Turn off serial communication while using serial ports
pinMode(buzzer, OUTPUT);
pinMode(relay, OUTPUT);
pinMode(fan, OUTPUT);
digitalWrite(buzzer, LOW);
digitalWrite(relay, LOW);
digitalWrite(fan, LOW);
//sensors.begin();
tft.begin(0x3229);
tft.setRotation(2);
tft.fillScreen(BLACK);
tft.setTextColor(BLACK, YELLOW);
tft.setTextSize(2);
tft.setCursor(45, 5);
tft.print(" REFLOW IRON ");
tft.fillRect(45, 0, 156, 5, YELLOW);
tft.fillRect(45, 20, 156, 5, YELLOW);
tft.setAddrWindow(x, y, x + w - 1, y + h - 1);
tft.pushColors((const uint8_t*)fan1, w * h, 1, false);
tft.setAddrWindow(0, 0, tft.width() - 1, tft.height() - 1);
fanBtn.initButton(&tft, 220, 250, 18, 24, WHITE, BLACK, WHITE, "F", 2);
fanBtn.drawButton(false);
// initialise buttons
up1.initButton(&tft, 195, 108, 20, 20, WHITE, BLACK, WHITE, "+", 2);
dwn1.initButton(&tft, 220, 108, 20, 20, WHITE, BLACK, WHITE, "-", 2);
up1.drawButton(false);
dwn1.drawButton(false);
up2.initButton(&tft, 195, 143, 20, 20, WHITE, BLACK, WHITE, "+", 2);
dwn2.initButton(&tft, 220, 143, 20, 20, WHITE, BLACK, WHITE, "-", 2);
up2.drawButton(false);
dwn2.drawButton(false);
up3.initButton(&tft, 195, 178, 20, 20, WHITE, BLACK, WHITE, "+", 2);
dwn3.initButton(&tft, 220, 178, 20, 20, WHITE, BLACK, WHITE, "-", 2);
up3.drawButton(false);
dwn3.drawButton(false);
up4.initButton(&tft, 195, 213, 20, 20, WHITE, BLACK, WHITE, "+", 2);
dwn4.initButton(&tft, 220, 213, 20, 20, WHITE, BLACK, WHITE, "-", 2);
up4.drawButton(false);
dwn4.drawButton(false);
on_btn.initButton(&tft, 60, 295, 100, 40, WHITE, 0x068B, WHITE, "START", 2);
off_btn.initButton(&tft, 180, 295, 100, 40, WHITE, 0xF340, WHITE, "RESET", 2);
on_btn.drawButton(false);
off_btn.drawButton(false);
void loop(void)
if (millis() - previousMillis >= 1000) {
previousMillis = millis();
temp = thermocouple.readCelsius(); // get temperature from thermocouple
//sensors.requestTemperatures();
//temp1 = sensors.getTempCByIndex(0); // get ambient temperature
if (reflowing) {
// pre heating stage
if (temp < preHeat)
tft.drawRect(0, 90, 240, 35, RED);
// reflow stage
if (temp > preHeat) {
tft.drawRect(0, 90, 240, 35, BLACK);
tft.drawRect(0, 125, 240, 35, GREEN);
// turn off the heating element if temp exceeds set reflow temp
if (temp > reflow) {
// turn it back on otherwise
if (temp < reflow) {
digitalWrite(relay, HIGH);
// countdown timer
timer--;
// timer finished
if (timer == 0) {
reflowing = false; // turn off reflow
cooling = true; // turn on cooling
digitalWrite(relay, LOW); // turn off relay
digitalWrite(buzzer, HIGH); // turn off buzzer
digitalWrite(buzzer, LOW); // turn off buzzer
tft.drawRect(0, 125, 240, 35, BLACK);
mm = timer / 60;
ss = timer % 60;
tft.fillRect(130, 203, 50, 20, BLACK);
tft.fillRect(30, 233, 120, 40, BLACK);
tft.fillRoundRect(115, 40, 115, 41, 15, RED);
if (cooling) {
delay(50);
tft.pushColors((const uint8_t*)fan2, w * h, 1, false);
delay(50);
if (temp > coolDown) {
digitalWrite(fan, HIGH);
tft.drawRect(0, 160, 240, 35, BLUE);
if (temp < coolDown) {
cooling = false;
timer = saveTimer;
tft.drawRect(0, 160, 240, 35, BLACK);
bool down = Touch_getXY();
// Start | Reset
on_btn.press(down && on_btn.contains(pixel_x, pixel_y));
off_btn.press(down && off_btn.contains(pixel_x, pixel_y));
if (on_btn.justPressed()) on_btn.drawButton(true);
if (off_btn.justPressed()) off_btn.drawButton(true);
if (on_btn.justReleased()) {
on_btn.drawButton();
if (timer > 30) {
saveTimer = timer;
reflowing = true;
mm = timer / 60;
ss = timer % 60;
if (off_btn.justReleased()) {
off_btn.drawButton();
asm volatile ("jmp 0"); // reset
// PreHeat
up1.press(down && up1.contains(pixel_x, pixel_y));
dwn1.press(down && dwn1.contains(pixel_x, pixel_y));
if (up1.justPressed()) up1.drawButton(true);
if (dwn1.justPressed()) dwn1.drawButton(true);
if (up1.justReleased()) {
up1.drawButton();
tft.fillRect(130, 98, 50, 20, BLACK);
preHeat++;
if (dwn1.justReleased()) {
dwn1.drawButton();
preHeat--;
// Reflow
up2.press(down && up2.contains(pixel_x, pixel_y));
dwn2.press(down && dwn2.contains(pixel_x, pixel_y));
if (up2.justPressed()) up2.drawButton(true);
if (dwn2.justPressed()) dwn2.drawButton(true);
if (up2.justReleased()) {
up2.drawButton();
tft.fillRect(130, 133, 50, 20, BLACK);
reflow++;
if (dwn2.justReleased()) {
dwn2.drawButton();
reflow--;
// cooldown
up3.press(down && up3.contains(pixel_x, pixel_y));
dwn3.press(down && dwn3.contains(pixel_x, pixel_y));
if (up3.justPressed()) up3.drawButton(true);
if (dwn3.justPressed()) dwn3.drawButton(true);
if (up3.justReleased()) {
up3.drawButton();
tft.fillRect(130, 168, 50, 20, BLACK);
coolDown++;
if (dwn3.justReleased()) {
dwn3.drawButton();
coolDown--;
// set timer
up4.press(down && up4.contains(pixel_x, pixel_y));
dwn4.press(down && dwn4.contains(pixel_x, pixel_y));
if (up4.justPressed()) up4.drawButton(true);
if (dwn4.justPressed()) dwn4.drawButton(true);
if (up4.justReleased()) {
up4.drawButton();
timer += 5;
if (dwn4.justReleased()) {
dwn4.drawButton();
timer -= 5;
// fan
fanBtn.press(down && fanBtn.contains(pixel_x, pixel_y));
if (fanBtn.justPressed()) fanBtn.drawButton(true);
if (fanBtn.justReleased()) {
fanBtn.drawButton();
fanState = !fanState;
if (fanState) {
delay(50);
delay(50);
else {
tft.setTextSize(3);
tft.setTextColor(RED);
tft.setCursor(5, 50);
tft.print("Temp : ");
tft.setTextColor(WHITE);
tft.print(temp);
tft.print((char)247);
tft.print("C");
tft.setTextSize(2);
tft.setCursor(10, 100);
tft.print("Pre Heat : ");
tft.print(preHeat);
tft.setCursor(10, 135);
tft.print("Reflow : ");
tft.print(reflow);
tft.setCursor(10, 170);
tft.print("Cooldown : ");
tft.print(coolDown);
tft.setCursor(10, 205);
tft.print("Timer(s) : ");
tft.print(timer);
tft.setTextSize(4);
tft.setCursor(30, 235);
tft.print(mm);
tft.print(":");
if (ss < 10) tft.print(0);
tft.print(ss);
tft.setTextSize(2);
Everything is ok just the touchscreen is flipped horizontally.
when I try 1st time this code touch screen does not work at all then I change the values in the undermentioned lines
change here calibration values but not work
The touch screen works fine but the only problem is that when press start and then reset click.
