I am trying to control the fan speed by sending a PWM to the fan modules. No signal and the fans go full high 5% and it should stay off. I had this working on a bread board but now that I moved it to a pref board I cannot control the fans anymore. This is how I have it wired currently any help would be appreciated.
I suspect that diagram is somewhat incomplete , the j modules probably have their own supply.
Could still be an earth problem.
EDIT
J291 and J671 appear to be automotive part nos.
On my car the fan is brushless.
Not at all sure they would be designed for PWM conntrol but do not know.
The fans are originally controlled by the engine control module via a pwm signal to the fan modules for different speed. This is a engine swap and the new engine control module does not control fans.
The example connection was made on a BMW vehicle. This system varies the fan speed by a change in duty cycle of the signal. The fan is at rest at 10% and at maximum speed at 90%. The fan or fans have a constant-voltage supply with the earth return path being switched though the vehicle's electronic control unit (ECM).
Eddiedellz:
What exactly happens , cannot turn them off ?
When you moved from breadboard to perf did anything else change ? Running the engine ?
EDIT
What are the FET's you used ?
When you soldered the fets did you use an earthed workstation ?
It is possible they have failed, you should be able to test for this with a multimeter though.
