Hello everyone i would like to know how can i make a matrix of computer fans (12V 0.2MA) basically 64 of them and connect this matrix to arduino. Im a complete knoob. i been seeing some led matrix examples but know i towards the servo motor example but they are all for 2 or 3 servos not 64 of them.
Can anyone help.
The big issue here is wether you want to just stat / stop the fans or you want individual speed control over each fan.
If you just want to start / stop them, then you can use shiftregisters to expand the number of digital out pins and a simple transistor + diode driver for each fan.
Individual speed control is going to be much more complex with that many fans / motors.
mem: hey mem good news then because those are quite cheap here where i live. the thing that i want to do will be made in processing and while get make the fans work via webcam like a virtual mirror kinda of thing. as for the code i am looking to get some time to start studying all the manuals on these vacations.
basically this:
webcam input ----> mac (processing getting data from 64 pixels on the image) ----> arduino -----> ????----> alot of computer fanas connected so that they can work individually.
Eight of them should drive your fans directly. Have a look at the datasheet, and I would thing google would help you find information on connecting serial latches to the arduino. Others may have suggestions for similar parts that would work in your app.
Please note that you can't have all 8 of the fans on at the same time from this driver because of the limit on the total package dissipation.
At 200mA there is a saturation voltage of 1.9v this gives a total power dissipation of 0.38W per motor. The graph on the data sheet shows 2W as the maximum package dissipation at 25c. This would suggest you can only run 2 / 0.38 = 5.2 fans.
The data sheet duty cycle table shows with all 8 outputs on at 200mA you can only run them on a duty cycle of 53% that is only on for about half the time. Otherwise the package will get too hot and the device will fail.
If you do need the fans to be all on at once then you have to restrict this chip to driving only four or five fans.
ok summer school electronics here i go.
thanks a lot for all of the replys
mem: thanks for the part i searching on how to relay it with arduino
Grumpy_Mike: even if i put a heat dissipator on top of it it would drive the eight fans ? or even if i run it at lower than 200mA (about 100mA) - do you know of a way to do this?
Mike, good point, but perhaps a little conservative assuming the application is not mission critical. The 1.9v saturation voltage is a maximum value and rated at 85 degrees Celsius ambient.
And the duty cycle graph is for 50 degrees Celsius.
If this was my project (and some diligent searching didn't' turn up a more suitable part) I would be tempted to test the chip under load and see how many fans can be driven before the chip temperature gets anywhere near 50 degrees.
Point taken, but these are the only temperatures given in the data sheet and lowering the temp it won't make that much difference to the saturation voltage. Also it's better mistakes are cleared up in the planning stage as it's cheaper to rectify. I have used similar devices in the past and they do get very hot when all outputs are running a fair current.
It's not as easy as that, it all depends on how good a heat dissipater you could make, you are in uncharted waters. You could probably calculate how good it needs to be in reduction of the thermal resistance of case to ambient (measured in degrees centigrade per watt) but how would you know that your heat sink was that good.
Yes that would help but you are saying the fan has to take half the amount of power, that means get a smaller fan or run it at half the voltage. I guess it wouldn't turn at that.
Just a thought to consider, the 74hc595 is much cheaper than the chip I linked above. , I think you could save some money if you used 8 75hc595 chips and 50 low power FETs (like the 2n7000). There is more soldering you need to do (and Mike will correctly point out that the 2n7000 is rated at a max current of 200ma so you will either need to ensure you fans are less than this or find a similar cheap FET that is rated a little higher.) The advantage of an FET is that you don't' need to solder 50 series resistors to between the 595 output and drivers.
If you mean for the 74hc595 and 2n7000 , the circuit really simple.
For each of the eight outputs from the 74hc595 do the following:
You would connect the output of the 595 to the gate of the 2n7000, connect the 2n7000 source to ground, the 2n7000 drain connects to the negative lead from the fan. Connect the positive fan lead to +12v. When the 74hc595 output is high the fan will be on, off when low.
See the datasheets for the pinouts on the 595 and 2n7000.
For testing, you can connect the 2n7000 gate directly to an arduino output. This controls only as many fans as you have digital pins but allows you to check that things are working by doing a digitalWrite on the pins to directly control a fan.
Note that the 2n7000 maximum continuous current is 200ma so check your fans to see if they exceed this.
You should be able to find how to connect the 595 using a google search
p.s. the tutorial for the 16 channel mpx is for analog, it wont work for what you want to do.
