i would like to play a pre-recorded human voice from a speaker when motion detects by the motion sensor. (i have arduino uno + motion sensor + speaker), and i want to ask that how can i play that file, which module is needed ?
should i buy and use WTV020-SD-16P
or
should i only use normal sd card reader to play a file to a speaker.
or should i buy any other shield or any other module..
I have a WTV020-SD-16P, but it pisses me off because I can't load files to the sd card without removing it, inserting it into my computer, loading the files, then re-inserting back into the WTV020-SD-16P. The Wi-Fi shield lets you download files to sd card without removing it from the module. The WTC020-SD-16P does not include this convenient feature.
I would also like to be able to stream straight to module.
Does anyone know if the Adafruit wave shield can do these things?
Does anyone have Lady Ada's contact information, or the contact information of someone else that designs things like this then? If arduino is to be superior, arudino users must have access to this superior technology!
Not yet, but I will!
Don't you design things like this?
While I have you, is there a way to have arduino power on when a 5 volt signal is received (duration of signal will be about 1 second), then have it turn itself off after 10 minutes? I need a more power efficient solution, but I don't know how to address it. The Wi-Fi shield is terribly greedy with power consumption.
