Hi, this is the code that I am using:
char dataIn = 'S'; //Character/Data coming from the phone.
int pinForwardBack = 13; //Pin that controls the car's Forward-Back motor.
int pinLeftRight = 12; //Pin that controls the car's Left-Right motor.
int pinBrakeLeftRight = 9; //Pin that enables/disables Left-Right motor.
int pinBrakeForwardBack = 8; //Pin that enables/disables Forward-Back motor.
int pinLeftRightSpeed = 3; //Pin that sets the speed for the Left-Right motor.
int pinForwardBackSpeed = 11; //Pin that sets the speed for the Forward-Back motor.
int pinfrontLights = 4; //Pin that activates the Front lights.
int pinbackLights = 7; //Pin that activates the Back lights.
char determinant; //Used in the check function, stores the character received from the phone.
char det; //Used in the loop function, stores the character received from the phone.
int velocity = 0; //Stores the speed based on the character sent by the phone.
//*************NOTE: If using Bluetooth Mate Silver use 115200 btu
// If using MDFLY Bluetooth Module use 9600 btu
Serial.begin(115200); //Initialize serial communication with Bluetooth module at 115200 btu.
pinMode(pinForwardBack, OUTPUT);
pinMode(pinLeftRight, OUTPUT);
pinMode(pinBrakeLeftRight, OUTPUT);
pinMode(pinBrakeForwardBack, OUTPUT);
pinMode(pinLeftRightSpeed , OUTPUT);
pinMode(pinForwardBackSpeed , OUTPUT);
pinMode(pinfrontLights , OUTPUT);
pinMode(pinbackLights , OUTPUT);
det = check();
while (det == 'F') //if incoming data is a F, move forward
digitalWrite(pinForwardBack, LOW);
digitalWrite(pinBrakeForwardBack, LOW);
analogWrite(pinForwardBackSpeed,velocity);
analogWrite(pinLeftRightSpeed,0); //To make the Left/Right Motor not move, you just need to make its speed 0.
det = check();
while (det == 'B') //if incoming data is a B, move back
digitalWrite(pinForwardBack, HIGH);
det = check();
while (det == 'L') //if incoming data is a L, move wheels left
digitalWrite(pinLeftRight, HIGH);
digitalWrite(pinBrakeLeftRight, LOW);
analogWrite(pinForwardBackSpeed,0); //To make the Forward/Back Motor not move, you just need to make its speed 0.
analogWrite(pinLeftRightSpeed,255);
det = check();
while (det == 'R') //if incoming data is a R, move wheels right
digitalWrite(pinLeftRight, LOW);
det = check();
while (det == 'I') //if incoming data is a I, turn right forward
det = check();
while (det == 'J') //if incoming data is a J, turn right back
det = check();
while (det == 'G') //if incoming data is a G, turn left forward
det = check();
while (det == 'H') //if incoming data is a H, turn left back
det = check();
while (det == 'S') //if incoming data is a S, stop
det = check();
while (det == 'U') //if incoming data is a U, turn ON front lights
digitalWrite(pinfrontLights, HIGH);
det = check();
while (det == 'u') //if incoming data is a u, turn OFF front lights
digitalWrite(pinfrontLights, LOW);
det = check();
while (det == 'W') //if incoming data is a W, turn ON back lights
digitalWrite(pinbackLights, HIGH);
det = check();
while (det == 'w') //if incoming data is a w, turn OFF back lights
digitalWrite(pinbackLights, LOW);
det = check();
int check()
if (Serial.available() > 0) //Check for data on the serial lines.
dataIn = Serial.read(); //Get the character sent by the phone and store it in 'dataIn'.
if (dataIn == 'F')
determinant = 'F';
else if (dataIn == 'B')
determinant = 'B';
else if (dataIn == 'L')
determinant = 'L';
else if (dataIn == 'R')
determinant = 'R';
else if (dataIn == 'I')
determinant = 'I';
else if (dataIn == 'J')
determinant = 'J';
else if (dataIn == 'G')
determinant = 'G';
else if (dataIn == 'H')
determinant = 'H';
else if (dataIn == 'S')
determinant = 'S';
else if (dataIn == '0')
velocity = 0; //"velocity" does not need to be returned.
else if (dataIn == '1')
velocity = 25;
else if (dataIn == '2')
velocity = 50;
else if (dataIn == '3')
velocity = 75;
else if (dataIn == '4')
velocity = 100;
else if (dataIn == '5')
velocity = 125;
else if (dataIn == '6')
velocity = 150;
else if (dataIn == '7')
velocity = 175;
else if (dataIn == '8')
velocity = 200;
else if (dataIn == '9')
velocity = 225;
else if (dataIn == 'q')
velocity = 255;
else if (dataIn == 'U')
determinant = 'U';
else if (dataIn == 'u')
determinant = 'u';
else if (dataIn == 'W')
determinant = 'W';
else if (dataIn == 'w')
determinant = 'w';
return determinant;
The problem I seem to be having is that, when using this code, the bluetooth shield does not search for or connect to my android phone. The problem is not with the bluetooth shield as it connects to my phone easily using another code.
Any suggestions?
P.S. I have also experimented with this code (see hyperlink) but have encountered the same problem. http://letsmakerobots.com/node/24779
