Arduino Uno and 5V Pump without Relay
You mean this?
I just unplugged it for a better view
I think the polarity is correct.
If I plug it the other way round nothing will happen.
Thank you for clarification.
Is the diode around the right way?
This is impossible, I'm out. good luck.
Lol it now works, I had to let the pump flutter 15 seconds and at the end the pump ran.
Before I only tried for a few seconds because I didn't want to damage it
Sounds like it needed to prime itself.
Tom.. :grinning: :+1: :coffee: :australia:
Thank you all for your patience!
So the pump is now running again with the MOSFET.
This is my circuit:
This is my program:
int pumpPin = 9;
  pinMode(pumpPin,OUTPUT);
  Serial.println("Motor");
  digitalWrite(pumpPin, HIGH);
  delay(5000);
  digitalWrite(pumpPin, LOW);
  delay(5000);
The red LED on the MOSFET alternates between ON and OFF.
When the LED is ON, the pump is on 100%
When the LED is OFF, the pump is on 50%
How to turn the pump off? :frowning:
I also tried to connect the TRIG/PWM directly to arduino 5V instead of the digital pin 9, but that will give 100% permanently.
