Arduino UNO and Bluetooth Module SKU 80711 (DealExtreme)
Hello,
I have a little problem since the Arduino UNO Board ( Pin Tx and Pin Rx) works with 5Volts and this Bluetooth Module with 3.3Volts.
I would like to know what can I use to communicate this devices.
I hope someone can help me
Hello LuisFe.
In the link you have an example:
Hi LuisFe,
I made the paperbluetooth for that module. And it works as Inizul says. You can see my Ecobot with android, with a range of 15 meters. Ecobot on Vimeo
You dont need to solder pin 34. And also you don't need the jumper J1.
Good luck.
Nayma
Thanks a lot!, nayma...Is there a way to get the code of that android app to understand the code ?
You can download the blueterm code. It's Java, you can modify it with eclipse.
