Hi.
I have an Arduino Uno R3, it used to work well, but it doesn't work anymore, I can't upload code to the board because everytime I try I get this error message:
Arduino:1.8.1 (Windows 10), Tarjeta:"Arduino/Genuino Uno"
El Sketch usa 928 bytes (2%) del espacio de almacenamiento de programa. El máximo es 32256 bytes.
Las variables Globales usan 9 bytes (0%) de la memoria dinámica, dejando 2039 bytes para las variables locales. El máximo es 2048 bytes.
Ha ocurrido un error mientras se enviaba el sketch
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x3e
Problema subiendo a la placa. Visita http://www.arduino.cc/en/Guide/Troubleshooting#upload para sugerencias.Este reporte podría tener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
1 - The Operative System does recognize the Arduino board. It does.
2 - The Arduino Software does recognize the Arduino board. It does too.
3 - Any Led on the board doesn't gets on ONLY the "L" Led which is ALWAYS on.
4 - TX and RX LEDs doesn't do anything when I try to upload code to the Arduino board.
5 - Reset button doesn't do anything.
6 - I tried several ATMega Chips and it's the same... They work well when they are in other Arduino Board.
If someone could help me to fix it, if there is a way to fix it, I would be thankful.
Thanks.
