Hallo, ich kann keine codes mehr auf meine arduinos laden. Habe schon mehrere probirt (Mega 2560, verschiedene Uno boards).
Fehlermeldung: Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
Der Sketch verwendet 2648 Bytes (8%) des Programmspeicherplatzes. Das Maximum sind 32256 Bytes.
Globale Variablen verwenden 224 Bytes (10%) des dynamischen Speichers, 1824 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x4d
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x4d
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x4d
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x4d
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x4d
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x4d
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x4d
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x4d
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x4d
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x4d
Problem uploading to board. See Upload – Arduino Help Center for suggestions.
Mein Code lautet:
const char R1=8; //Releis
const char R2=9;
const char R3=10;
const char R4=11;
const int SW_pin = 2; // Taster-Pin
const int X_pin = A0; // X-Ausgang
const int Y_pin = A1; // Y-Ausgang
int Gk=0;
int I=0;
pinMode(R1, OUTPUT);
pinMode(R2, OUTPUT);
pinMode(R3, OUTPUT);
pinMode(R4, OUTPUT);
// Releis als Output definieren und Ausschalten
digitalWrite(R1, LOW);
digitalWrite(R2, LOW);
digitalWrite(R3, LOW);
digitalWrite(R4,LOW);
pinMode(SW_pin, INPUT); //Joystick Taster
digitalWrite(SW_pin, HIGH);
Serial.begin(9600); //Seral Monitor
Serial.println("Start");
Serial.print("Stick: ");
Serial.print(digitalRead(SW_pin));
Serial.print("\n");
Serial.print("X-Achse: ");
Serial.print(analogRead(X_pin));
Serial.print("\n");
Serial.print("Y-Achse: ");
Serial.println(analogRead(Y_pin));
Serial.print("\n\n");
