Arduino UNO controlling led's on outputs
Hello
Do you looking for "simple" solution or do you learn how to code?
hi thanks im looking for both simple solution and understand what the solution is
Hello, please make the following changes.
if(data=='R')//LED ON
digitalWrite(11,LOW);
digitalWrite(12,LOW);
digitalWrite(13,HIGH);
else (data=='S');//LED Off
digitalWrite(13,LOW);
if(data=='Y')//LED ON
digitalWrite(12,HIGH);
else (data=='Z');//LED Off
if(data=='G')//LED ON
digitalWrite(11,HIGH);
else (data=='H');//LED Off
Hello
This a very "simple" solution using OOP. I“ve made an object and a method to handle the activities.
/* BLOCK COMMENT
  ATTENTION: This Sketch contains elements of C++.
  https://www.learncpp.com/cpp-tutorial/
  https://forum.arduino.cc/t/arduino-uno-controlling-leds-on-outputs/936156
#define ProjectName "Arduino UNO controlling led’s on outputs"
#define OutPutTest
constexpr  unsigned long OutPutTestTime {1000};
struct KEYLED {
  byte key;
  byte pin;
  bool state_;
KEYLED keyLeds[] = {
  {'R', 13, HIGH},
  {'S', 13, LOW},
  {'Y', 12, HIGH},
  {'Z', 12, LOW},
  {'G', 11, HIGH},
  {'H', 11, LOW},
  Serial.println(F("."));
  Serial.print(F("File   : ")), Serial.println(__FILE__);
  Serial.print(F("Date   : ")), Serial.println(__DATE__);
  Serial.print(F("Project: ")), Serial.println(ProjectName);
  pinMode (LED_BUILTIN, OUTPUT);  // used as heartbeat indicator
  //  https://www.learncpp.com/cpp-tutorial/for-each-loops/
  for (auto keyLed : keyLeds) pinMode(keyLed.pin, OUTPUT);
#ifdef OutPutTest
  // check outputs
  for (auto keyLed : keyLeds) digitalWrite(keyLed.pin, HIGH), delay(OutPutTestTime);
  for (auto keyLed : keyLeds) digitalWrite(keyLed.pin, LOW), delay(OutPutTestTime);
#endif
void loop () {
  digitalWrite(LED_BUILTIN, (millis() / 500) % 2);
  if (Serial.available()) {
    byte data = Serial.read();
    Serial.println((char) data);
    for (auto &keyLed : keyLeds) if (data == keyLed.key) digitalWrite( keyLed.pin, keyLed.state_);
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Oh... Ok Thank you. Actually I am new here. Still learning the rules.
When you tried to post your code without code tags did you get a message suggesting that you use code tags ?
