Arduino uno + Hall sensor output to U8glib / 12864 graphic LCD ST7920
Hi and sorry but I just cant get my code to output anything to the display...
Can anyone help I think iam overlooking somthing....
// using a hall sensor as a tachometer with a LCD display using U8glib / 12864 graphic LCD ST7920
#include "U8glib.h"
#define PMS_PIN 3 // Pin for signal from hall sensor
#define LED_PIN 13 //Using Arduino's Internal LED as an hall sensor indicator for testing the signal.
boolean counted=false;
int t1=0,t2=0;
int hits=0;
int rps=0;
U8GLIB_ST7920_128X64_4X u8g(11, 10, 12); // this is the 12864 graphic LCD ST7920 using pin 11,10,12
void u8g_prepare(void) {
  u8g.setFont(u8g_font_6x10);
  u8g.setFontRefHeightExtendedText();
  u8g.setDefaultForegroundColor();
  u8g.setFontPosTop();
void setup(){
  pinMode(PMS_PIN, INPUT);
  pinMode(LED_PIN, OUTPUT);
   // flip screen, if required
  //u8g.setRot180();
  // assign default color value
  if ( u8g.getMode() == U8G_MODE_R3G3B2 )
    u8g.setColorIndex(255);     // white
  else if ( u8g.getMode() == U8G_MODE_GRAY2BIT )
    u8g.setColorIndex(3);         // max intensity
  else if ( u8g.getMode() == U8G_MODE_BW )
    u8g.setColorIndex(1);         // pixel on
  //u8g.setContrast(0x30);
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);
  u8g_prepare();
void loop(){
  t2 = millis();
  if(t2 >= (t1 + 10)){
    rps = hits;
    hits = 0;
    t1=t2;
    uint8_t u8g_Begin(u8g_t *u8g);
    u8g.print("RPM: ");
    u8g.print(rps*60);
  if(digitalRead(PMS_PIN) == HIGH){
    if(!counted){
      counted = true;
      hits++;
    counted = false;
  digitalWrite(LED_PIN, digitalRead(PMS_PIN));
is probably useless and might lead to a syntax error.
Additionally, you need to enclose the print commands into the "picture loop":
Replace
    u8g.print("RPM: ");
    u8g.print(rps*60);
with
  u8g.firstPage();
  do {
    u8g.print("RPM: ");
    u8g.print(rps*60);
    draw();
  } while( u8g.nextPage() );
Oliver
Hi thanks
I get a error with you code:
void loop(){
  t2 = millis();
    rps = hits;
    hits = 0;
    t1=t2;
    //uint8_t u8g_Begin(u8g_t *u8g);
      u8g.firstPage();
  do {
    u8g.print("RPM: ");
    u8g.print(rps*60);
    draw();
    if(!counted){
      counted = true;
      hits++;
    counted = false;
I get a:
sketch_oct04a.ino: In function 'void loop()':
sketch_oct04a:59: error: 'draw' was not declared in this scope
Did I miss something?
Hi again
I can get display to output the text ( RPM and speed) if i use "void draw(); but the text is all over the display its like sceensaver, how do i stop this. it looks like its moving with the update here:
void loop(){
  t2 = millis();
  if(t2 >= (t1 + 500)){
    rps = hits;
    hits = 0;
    t1=t2;
      u8g.firstPage();
  do {
    u8g.print("RPM: ");
    u8g.print(rps*60);
    void draw();
    if(!counted){
      counted = true;
      hits++;
    counted = false;
This is the updated code:
#include "U8glib.h"
int t1=0,t2=0;
int hits=0;
int rps=0;
void setup(){
  //u8g.setRot180();
  u8g_prepare();
void loop(){
  t2 = millis();
  if(t2 >= (t1 + 1000)){
    rps = hits;
    hits = 0;
    t1=t2;
      u8g.firstPage();
  do {
    u8g.print("RPM: ");
    u8g.print(rps*60);
    void draw();
    if(!counted){
      counted = true;
      hits++;
    counted = false;
Hi
You can remove the line with "draw()" completly. That was copy-paste error from my side.
Oliver
