Arduino UNO IR Reader+ Remote
I am new but want to make something cool with the IR reader and remote but dont know what pls help. (sorry if spell something wrong not good english)
With 6 digit code
Make the IR work. Then think about some interesting thing for the controller to do.
but i dont know how and i am new and dont find a video
Install this library https://docs.arduino.cc/libraries/irremote/ look at the examples. There will be an example that will print out the values received from the remote. Connect a 3 pin IR receiver module and press buttons on the remote, you should see the received codes on the serial monitor.
Do you have --
Arduino UNO R3
IR Receiver
Remote Control
Q: What do you want to achive?
A: I want to press a button on the Remote Control, receive the code sent by the Remotre, and then display the received code on the Serial Monitor in hex format.
i have the lybrary but do not have the reader you have on the picture
It’s called a receiver, not a reader. I understand you, but if you want to search for one then use “IR receiver”. Do you have anything to receive the IR? If you need to buy one, see the note under the picture TSOP4838.
