Arduino UNO & Linksprite Shield RS232 v2 - send message to RS232
I 'm quite new with electronics, so pardon me if mistaken.
I have the following components:
  • Arduino UNO
  • Linksprite RS232 Shield v2
My goal is to dispatch from a static message (static at the moment - I plan to add an Ethernet shield later and relay a message from UDP port) from arduino to DB-9 port.
For my coding/testing environment I am using a PC with a USB and RS232 port (COM1) and a null modem cable.
The steps that I followed in order to accomplish it are:
  1. Soldered the pins on RS232 shield v2 (20151022_154938.jpg)
  2. Hooked up the RS232 shield on the arduino
  3. Set pin 2 as TX (20151022_154927.jpg)
  4. Set pin 3 as RX (20151022_154927.jpg)
  5. Opened IDE and uploaded the following code:
#include <SPI.h>
#include <Ethernet2.h>
#include <EthernetUdp2.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(3,2);
    mySerial.begin(9600);
    Serial.println("begin initial Serial USB!\n");
    mySerial.println("begin initial Serial DB-9!\n");
  mySerial.println ("static message DB9");
  Serial.println ("static message USB");
  1. The code runs and on serial monitor I get the message "static message USB". The TX led on the RS232 shield is blinking every second (as it should)
  2. I hook the null modem cable to DB-9 connector of the shield and then on the PC.
  3. I open putty on COM1 (9600 baud , 8N1), BUT MY PROBLEM IS THAT I DO NOT GET ANY MESSAGES (static message DB9).
Any ideas?
Thank you all in advance
I managed to make it work by performing the following change:
SoftwareSerial mySerial(2, 3);
Right now I am able to view messages sent both on USB & DB-9 port using putty.
The next step is to make it work with Ethernet shield v2 and relay a message to DB-9 from UDP port.
The code that I am using right now is:
#include <SPI.h>
#define UDP_TX_PACKET_MAX_SIZE 1024
byte mac[] = {
  0x90, 0xA2, 0xDA, 0x10, 0x01, 0xED
IPAddress ip(10, 15, 120, 47);
IPAddress gateway(10, 15, 120, 1);
IPAddress subnet(255, 255, 255, 0);
unsigned int localPort = 8888;
// buffers for receiving and sending data
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
char  ReplyBuffer[] = "acknowledged";       // a string to send back
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
  // start the Ethernet and UDP:
  Ethernet.begin(mac, ip, gateway, subnet);
  Udp.begin(localPort);
  // if there's data available, read a packet
  int packetSize = Udp.parsePacket();
  if (packetSize)
    IPAddress remote = Udp.remoteIP();
    Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
    Serial.println(packetBuffer);
    mySerial.println(packetBuffer);
    Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
    Udp.write(ReplyBuffer);
    Udp.endPacket();
    for (int i = 0; i < UDP_TX_PACKET_MAX_SIZE; i++) {
      packetBuffer[i] = 0;
  delay(10);
I am facing the following 2 problems:
  • In case I change the baud rate to 1200 instead of 9600 for both serial ports, I do get the message on COM, but I do not get the message on DB-9
  • In case the baud rate is 9600 and the messages are in Greek they are not correctly displayed on DB-9 - even though I change the encoding on putty and they are correctly displayed on IDE's Serial Monitor
I would really appreciate any help.
Thank you in advance.
I managed to fix both problems !!!
  1. I hook the null modem cable to DB-9 connector of the shield and then on the PC.
I attached a normal cable to DB-9 connector and everything works as expected.
I tested both 1200 baud rate and Greek encoding and it works flawlessly.
